Author Topic: Gearshift Problem....  (Read 32780 times)
Offline CocoPops
    • Kennet Heath
« on: June 14, 2009, 05:50:40 pm »
Guys,
Currently in France, due back tomorrow.
I've got a strange issue...
I can select all gears no problem...
But...
It's as if the "gate" for the lower 2,4,6 gears is missing....
ie I can select 1st, 3rd, 5th and the stick does not wobble.
However, if I select 2nd, 4th, 6th then the stick moves side to side and I can only leave the gear if I remember what gear I'm in...
Make sense?
A poor diagram......
#1#3#5#
#2 4 6#
Any one have any ideas?
Not sure if it's the Quick Shift causing it?
It's a VW Racing one, fitted by VW Racing last weekend.
I've done plenty of gear changes and miles over the last week since fitting, but it's the only thing thats changed.
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Phil Mcavity
Re: Gearshift Problem....
« Reply #1 on: June 14, 2009, 05:51:32 pm »
Sounds like your Bargain short shifter from vwr has come loose mate, maybe slipped a spline on the shaft causing the problem.
Seems a tad coincidental that they fitted it just last week and you now have gear shaft alignment issues.
Hope the Trip has gone well to Le mans. Hope youve taken lots of piccies to show all when you get back mate. :happy2:
« Last Edit: June 14, 2009, 05:56:03 pm by Phil Mcavity »
Offline WhiteGTI
  • F-A-S-T
« Reply #2 on: June 14, 2009, 05:59:01 pm »
I've had experience with this, it sounds like the connection where the front-back and side-side shifter is coming a little loose...should be an easy fix, but i don't have experience of the VWR product - only the Forge. Have a look at it and look at the connector block where the two shifters connect.
Sorry I cannot be more helpful  :happy2:
2006 E46 BMW M3 - 343hp
Phil Mcavity
« Reply #3 on: June 14, 2009, 06:03:10 pm »
Is there some sort of pinch bolt that tightens to stop the shaft from slipping off a spline do you know chris? perhaps its that ,thats come loose.?
Offline CocoPops
    • Kennet Heath
« Reply #4 on: June 14, 2009, 06:04:50 pm »
Chris,
That sounds about, will take a look.
If anyone else has any thoughts, do shout.
I'm hoping it's nothing serious and I can get back to UK ok.
Offline CocoPops
    • Kennet Heath
« Reply #5 on: June 14, 2009, 06:06:04 pm »
Also, does anyone (Robin?) have a mobile contact for Mark?
I really don't wanna need to call him on a Sunday, but stuck in France isn't the best thing....
Offline 182_blue
  • -Receive: 54
« Reply #6 on: June 14, 2009, 06:07:12 pm »
hope you get it sorted, i wouldnt be to impressed if it was mine
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #7 on: June 14, 2009, 06:15:13 pm »
I am not sure you will be able to raise him as he's up in Scotland racing this weekend  :chicken:
Offline WhiteGTI
  • F-A-S-T
« Reply #8 on: June 14, 2009, 06:33:54 pm »
On the Forge item, the two shifters pivot with eachother in a white plastic block. They connect to eachother slightly differently..there is what looks like a thick screwhead that slides into a hollow shaft, which is held together with a washer on the end. Only the front-back shifter sits on the main spline that goes into the gearbox.
I've just tried to have a look at mine but can't see too much because the Carbonio is in the way, but if you look where the two shifters pivot with eachother (just play with the shifter with your hands and you'll soon see this) you should be able to see if one is loose, or not pivoting correctly.
If this is the case, it may be a simple fix of just needing more grease, or maybe (as what happened in my case), the plastic block where they pivot has changed position, and just needs re-alligning.
EDIT:: Another thing to look for is check that the springs (it has square shaped ruffled-type plastic around it) that connects the gear lever to the actual shifters is still in place. This is probably not the reason, but maybe one of the securing clips has fallen off and has caused them to be a bit loose. But I don't think this is your problem...
This is the fitting instructions for the Forge part, it may give you an indication as to what to look for:
http://www.forgemotorsport.co.uk/media/Short%20Shifter%20Install(1).pdf
« Last Edit: June 14, 2009, 06:40:57 pm by WhiteGTI »
« Reply #9 on: June 14, 2009, 06:35:27 pm »
....I sent you a PM with his moby # :smiley:
« Reply #10 on: June 14, 2009, 06:53:34 pm »
its the side to side action just push it back in as it might have popped out
« Reply #11 on: June 14, 2009, 06:57:15 pm »
 :happy2: just push it back on
« Reply #12 on: June 14, 2009, 07:12:11 pm »
make sure u have a little slider on the side to side part
Offline QD MBE
  • -Receive: 102
« Reply #13 on: June 14, 2009, 07:24:14 pm »
x2
Offline CocoPops
    • Kennet Heath
« Reply #14 on: June 15, 2009, 08:24:09 am »
Not heard from mark yet...
It is the side side action that is screwed for some reason.
The black bracket doesnt sit in the channel it should do.
Have tried to relocate, no joy.
Currently limping through france towards calais.
