Author Topic: That beautiful f***#*g yellow light - now with log files  (Read 10910 times)
Offline gazbutS3
Re: That beautiful f***#*g yellow light - now with log files
« Reply #30 on: October 22, 2012, 10:03:12 pm »
:signLOL:  if it was a failed PCV would it affect my performance, and is it safe to drive?
yes you would loose boost :smiley: I think it'll be ok to drive but I wouldn't drive it too hard
again I could be talkin bollox  :smiley:
Offline Jussa
  • Bicester
« Reply #31 on: October 22, 2012, 10:06:57 pm »
Mmmmm, well it's in next week so I won't drive her too much.
I was meant to go to Regal tomorrow for a DSG reading for GIAC but I may put that on the backburner till this is sorted  :sad1:
« Reply #32 on: October 22, 2012, 10:14:51 pm »
Easy way to tell if the PCV is fubar'd is to pull the dipstick on idle. If it coughs and splutters then the PCV is ok.  :smiley:
Not sure about it affecting boost Gaz.
« Reply #33 on: October 22, 2012, 10:15:33 pm »
Well... as regal are REVO dealers they should be able to liaise with REVO HQ to make sure its not a map issue.
Offline gazbutS3
« Reply #34 on: October 22, 2012, 10:22:41 pm »
pretty sure the stock system uses positive boost as part of it operation, goes off to look  :smiley:
Offline Jussa
  • Bicester
« Reply #35 on: October 22, 2012, 10:30:07 pm »
What happens if it doesn't cough and splutter??
 :signLOL:
Offline gazbutS3
« Reply #36 on: October 22, 2012, 10:31:17 pm »
knew I'd read it somewhere, the standard valve uses positive boost pressure to close, so if it springs a leak boost pressure would be lost????
http://www.mk5golfgti.co.uk/forum/index.php?topic=7040.0
« Reply #37 on: October 22, 2012, 10:48:38 pm »
How come a fooked PCV messes up your idle? Not much boost being developed at tickover.  :smiley:
« Reply #38 on: October 22, 2012, 11:10:12 pm »
Probably because the vacuum in the intake is pulling pressure on the crankcase....
no idea...  :signLOL:
Offline vRSAlex
  • -Receive: 253
« Reply #39 on: October 23, 2012, 08:19:19 am »
Can't see it being the map this time.  Been on for too long before the fault has come up.  Would have come on within a day.
Has your oil level risen?
Follow AKS tuning on Facebook
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #40 on: October 23, 2012, 10:17:41 am »
You thinking fuel in the oil Alex?
Check Pcv, take dipstick out and if it coughs splutters its working fine, if stays the same then broke... how is your idle?
Have you had the map update?
What plugs are you using? Not burning the fuel at tick over, too cold a grade?
Ecu obviously chucking few in to compensate... any other sensors? but surely they would throw a fault?
Diesel Daily Hack.
Offline Jussa
  • Bicester
« Reply #41 on: October 23, 2012, 10:39:17 am »
No issues I can feel when driving  :confused: I had my oil light come on about 3 weeks ago so topped up with 1 litre of Castrol Edge.  Didn't think much of it as its the first time she's complained about oil since her service in December last year.
So probably can rule out the fuel in the oil, unless I need to check that again??
Not sure what plugs they are, I think whichever Audi had recommended last year, probably Bosch - service was done by Awesome GTi when they were still Revo.
Oil in the fuel, could that be the HPFP??  :scared:
