September 02, 2026, 02:23:27 am
All Things Mk5
Mk5 General Area
Battery Ah
Topic: Battery Ah (Read 1857 times)
Mertyvw
Always Involved
-Given: 11
-Receive: 7
Battery Ah
October 27, 2012, 12:34:24 pm »
What is the recommened or preferrd battery AH for TDI . I went on eurocarparts and it gives 74AH . If i put an 80Ah or above would it be ok ?
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
bacillus
Just look at my post count
-Given: 4
-Receive: 453
Re: Battery Ah
Reply #1 on:
October 27, 2012, 12:43:54 pm »
Yes but that may be overkill plus the higher amperage battery may be larger than the standard one and not fit without removing the car's battery protective case.
coolhandluke
Always Involved
-Given: 28
-Receive: 11
Re: Battery Ah
Reply #2 on:
October 27, 2012, 01:20:57 pm »
Other than waiting for your battery to just die and leave you stranded how do you know when its time for a replacment?
Can you have it checked and when should you change it?
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Re: Battery Ah
Reply #3 on:
October 27, 2012, 01:36:16 pm »
most garages have a battery load test machine
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
Mertyvw
Always Involved
-Given: 11
-Receive: 7
Re: Battery Ah
Reply #4 on:
October 27, 2012, 01:37:52 pm »
Brcause my AH is only 63 and ive seen posts on tdiforums thats it. Should be a min 72ah and preferabbly 80ah . With the lower Ah it.effects the cars performance. Thats what they say
david25
Always Involved
-Given: 19
-Receive: 7
Re: Battery Ah
Reply #5 on:
October 27, 2012, 07:55:48 pm »
The smallest fitted to the GTI I have seen is Varta 60 ah / 480A battery ( VW # 1J0 915 105 AC )
If you dont have heated seats and similar you could get one and save a few kilos.
I am running one on a basic GTI and its been fine.
Mertyvw
Always Involved
-Given: 11
-Receive: 7
Re: Battery Ah
Reply #6 on:
October 27, 2012, 08:50:40 pm »
I dont get it if the ah goes down does the ampage go up ir sUmmit?
david25
Always Involved
-Given: 19
-Receive: 7
Re: Battery Ah
Reply #7 on:
October 28, 2012, 06:14:57 am »
No, AH is how long the battery "lasts" and the other figure is cold crank, how much the battery can give in a burst (for starting).
All Things Mk5
Mk5 General Area
Battery Ah
