Author Topic: engine light on after removing intake  (Read 3101 times)
Offline webby888
« on: November 03, 2012, 11:50:26 am »
atm my car currently has a stage one map and an intake, few days ago i removed the intake and put the standard airbox back on for a quieter setup
however a few miles down the road the engine light came on and the garage said the fault was cam timing. so i had the cam belt changed and a service as it was almost due anyway. however the light is still on?
Is it just by chance that the light came on after i removed the intake or is it something i could have done?
Offline bacillus
  • -Receive: 453
Re: engine light on after removing intake
« Reply #1 on: November 03, 2012, 01:08:10 pm »
Did you reconnect the maf?
« Reply #2 on: November 03, 2012, 01:10:36 pm »
... and in the correct orientation.
Offline webby888
« Reply #3 on: November 03, 2012, 03:06:03 pm »
Yeah I screwed it back in, I fort it only fits one way in? I did check this but the holes didnt line up one way
Offline bacillus
  • -Receive: 453
« Reply #4 on: November 03, 2012, 03:20:19 pm »
Assuming all your intake hoses are secure and not leaking then your best course of action would be to get someone to do a vcds scan and post the fault code here. Without a fault code everyone would just be guessing.
Offline rjc
« Reply #5 on: November 04, 2012, 06:00:05 pm »
I had the same, but I had forgot to plug in the MAF sensor.
Offline 56OctyVRS
  • -Receive: 72
« Reply #6 on: November 06, 2012, 12:17:55 pm »
The garage that scanned it for you should tell you what the fault code was and whether they cleared the fault code or not. Seems odd your cam timing should go out soon after changing back to the oe cover. Have you refitted the seal that goes around the maf sensor as that will cause a leak and cause a light to come on.
Offline Dan.b
« Reply #7 on: November 06, 2012, 11:22:49 pm »
I managed to catch the cam sensor plug when I fitted my intake which brought the EML up. Turns out I broke a wire in the connector so needs replacing!
Offline webby888
« Reply #8 on: November 07, 2012, 05:26:45 pm »
how much did that cost to sort out?
Offline Dan.b
« Reply #9 on: November 10, 2012, 09:37:16 am »
Got a 2nd hand sensor for £25 which I will be fitting next week.
Offline webby888
« Reply #10 on: November 11, 2012, 10:54:05 pm »
cool cheers, is the sensor easy to see so i can check if i have damaged mine?
