Author Topic: oil filter housing  (Read 5805 times)
Offline s2martyn
oil filter housing
« on: November 07, 2012, 11:47:44 pm »
tightening up the filter today and CRACK,now is this lickely to be the part the filter sits in or the housing thats attached to the block,i could see oil ousing out but was too dark to confirm which...anyone else had the same issue??
Offline andygo
Re: oil filter housing
« Reply #1 on: November 08, 2012, 09:33:06 am »
The plastic housing on my ed30 cracked whilst attempting to undo it with a socket.
It's great design (plastic FFA) meant I had to buy a new one.
About £35 iirc.
Offline biffobear
« Reply #2 on: November 08, 2012, 03:46:00 pm »
is there a part number for it?
Offline SteveyD
« Reply #3 on: November 08, 2012, 10:43:06 pm »
Am I right in saying someone makes an alloy replacement APR or neuspeed rings a bell... Plastic housing + heat into metal thread = cheap fail!
Offline andygo
« Reply #4 on: November 09, 2012, 02:44:08 pm »
06D 115 408 B  filter housing
Offline njdudsbury
« Reply #5 on: November 09, 2012, 04:37:38 pm »
I did exactly the same cracked around the hexagon. Its a real bitch to get off if you have nipped it as there is no space to get in. Have you got it off? I paid about £40 for a new plastic one.
Offline s2martyn
« Reply #6 on: November 11, 2012, 06:14:00 pm »
going to remove it tommorrow to check ,theres a small oil drip now so something has cracked
Offline njdudsbury
« Reply #7 on: November 13, 2012, 12:21:00 pm »
Any news did you get it off?
Offline Jaywoo-GTI
  • -Given: 38
« Reply #8 on: November 13, 2012, 01:54:47 pm »
Even VW technicians manage to break these as it happened to my car whilst in  for a routine service and i was left with the only courtesy car they had left at the time. Polo diesel non turbo.  :sick:
if you have to buy another may be worth spending a little extra for piece of mind.
http://www.awesomegti.com/ecs-tuning-billet-aluminum-oil-filter-housing-kit-2-0t
Offline njdudsbury
« Reply #9 on: November 13, 2012, 09:46:07 pm »
did the broken / cracked one come off alright?
Offline njdudsbury
« Reply #10 on: November 16, 2012, 06:28:00 pm »
Anybody else broke one?
Offline s2martyn
« Reply #11 on: November 16, 2012, 06:43:57 pm »
got it off ok,split near the threads at the top,i must have over tightened it
Offline njdudsbury
« Reply #12 on: November 16, 2012, 10:12:01 pm »
What the thread that goes in the block or the hexagon you put the socket on?
