Author Topic: ESP light on!  (Read 2501 times)
Offline taylor
ESP light on!
« on: November 11, 2012, 08:30:49 pm »
So I've just had a light flash up with low tyre pressure now my ESP light has come on is this normal?
Tornado red ED30
Offline Martyboy70
Re: ESP light on!
« Reply #1 on: November 15, 2012, 09:31:48 pm »
Don't know if its normal but I had a similar problem with mine.it turned out to be the dreaded "brake pressure sensor" problem. I got mine replaced free of charge from VW otherwise it would have cost me over £1k !
170 GT TDI DSG
homesqueeze
Re: ESP light on!
« Reply #2 on: November 16, 2012, 04:02:20 pm »
Check your tyre pressures and then reset the tyre pressure monitor. This should clear the pressure monitor light and then if the esp light still stays then you will know there is some other problem going on.
Offline taylor
Re: ESP light on!
« Reply #3 on: November 16, 2012, 04:05:19 pm »
Yeah I've just up my tyre pressure as they were a bit low and the ESP light is still on I will have to take it to garage I bought it from as I still have a warranty on it
Tornado red ED30
homesqueeze
Re: ESP light on!
« Reply #4 on: November 16, 2012, 04:48:57 pm »
That sounds like the easiest thing to do  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: ESP light on!
« Reply #5 on: November 16, 2012, 07:43:59 pm »
a scan is required
Cluster and Key coding
Location Great Yarmouth
Offline taylor
Re: ESP light on!
« Reply #6 on: November 16, 2012, 09:15:01 pm »
Yeah I could do with vag-com scan
Tornado red ED30
Offline taylor
Re: ESP light on!
« Reply #7 on: November 17, 2012, 07:22:42 pm »
Ed you Coming up anywhere near the north east any time soon?
Tornado red ED30
Offline taylor
Re: ESP light on!
« Reply #8 on: November 22, 2012, 01:51:59 am »
Ah the f**king tyre pressure light has come back on and the tyre pressures are spot on
Tornado red ED30
