Author Topic: APR/Race Developments Stage 4+ 700hp+ TTRS Build  (Read 100261 times)
Offline Joshap1
Re: APR/Race Developments Stage 3+ TTRS Build
« Reply #180 on: May 20, 2015, 07:01:17 pm »
This car looks like an animal! Some serious firepower you've got there, bet it's a laugh to drive  :happy2:
Offline TaylorGTi
« Reply #181 on: May 22, 2015, 11:52:47 am »
Awesome read bud, had a cheeky stalk on your ig aswell and that thing sounds EPIC!  :happy2:
The patience you've had well, I just couldn't match haha!
Keep it up bud!
R-tech Stage 2+ Pirelli Gti
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #182 on: May 29, 2015, 01:07:45 pm »
Have you seen this:
https://www.facebook.com/revlimited/posts/645733625528061?notif_t=notify_me
Massive torque from this
Nice! Whats really interesting to me is the power curve difference to mine. Spool is a whole 750rpm later, shows what a good race developments did on the cylinder head porting and flowing. The aim was better low down response and thats exactly what I got.
Im still wondering if my 2.75" catback is holding power back a bit, I should really be a full 3", although I have 3.5" ambitions
2,75" must be a restriction, we are using 3,5" dp and 3" catback on the 2,0 TFSI above 450bhp  :happy2:
Yeah im thinking to go to 3.5" ready for when i do inevitably go for more power, but right now I have my hands full with 3 other details of the car that need adressing.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #183 on: May 29, 2015, 01:09:27 pm »
Keep it up bud!
Thanks guys. At times its tested my patience with the gearbox failures and then the injector failure, but everytime I drive it, I forgive her!
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #184 on: May 29, 2015, 01:30:23 pm »
Right lets try a meaningful update here.
May 2014 I went to the ring, and whilst in stop start traffic in belgium, the syncromesh went in 1st and 2nd gear. Bugger. Still made it to the ring and back though.
Got back to england, bought a 2nd hand gearbox and fitted that.
Fast forward to April 15' and the car develops a suspension knock. Into AMD it goes and they find that one of the bilstein dampers is weeping. Off it goes to bilstein who repaired it free of charge and back onto the car.
I pick the car up and 2 mins down the road from AMD and injector 5 fails. Get towed back to AmD and replace all 5 injectors.
I then fit dunlop sportmaxx race tyres, which then start rubbing on the outside arches/paintwork. Seems that they are fair bit wider than the michelin supersports that they replaced. Aggro! They would probably fit fine if it wasnt for the 10mm spacers I have to run to clear the 8 pots.
Solution? Wide Arches. Pics in the links :evilgrin:
https://instagram.com/p/23pToeSgXE/
https://instagram.com/p/3HSjwaygZr/
I also fitted a boost gauge, need little mod, has the needle sweep, black face when the car is off, and fits perfectly into the air vent.
https://instagram.com/p/2v0Lc9ygdf/
Then next on the list is further weight reduction. I had the car weighed when stock with nothing but a full milltek exhaust system at 1450kg with a quarter tank. Since then ive done the pole positions, titanium exhaust, rear seat removal and a lightweight battery will be on the way.
I estimate with all of these things the car probably weighs about 1365kg with a quarter tank.
https://instagram.com/p/3Q3__TygeH/
The rear seat is still a work in progress, im going to have a setup similiar to that of the special edition mk1 audi tt quattro sport. Should look cool once the parts arrive and I can get it fabricated.
Also awaiting my APR mobile dongle, so I can easily communicate with APR Hq in the states, as they are making me a custom map. Flames have been requested
« Last Edit: May 29, 2015, 01:33:50 pm by Poverty »
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #185 on: May 29, 2015, 01:37:03 pm »
Seems the forums dont like massive posts, as it keeps cutting parts off.
So to finish off the above:
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #186 on: May 29, 2015, 01:46:39 pm »
What an awesome car! BOMB!  :happy2:
I know you from the seatcupra times. ;)  :drinking:
Offline m1k3ydu8
  • Steel Grey MK5 R32
« Reply #187 on: May 30, 2015, 10:01:10 pm »
WOW! Hats off to you what an awesome build. :happy2:
Offline Orc
  • -Receive: 25
« Reply #188 on: June 01, 2015, 08:19:42 pm »
Hi buddy are you interested in selling your brakes?
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #189 on: February 20, 2016, 12:28:52 am »
Update:
Engines and gearbox coming out.
Gearbox getting rebuilt and engines off to racedevelopments for stage 4. Valvetrain, and schrick cams.
Then once back at rb race engineering raymond will be swapping the gtx3576 for a gtx3582. Looking to rev the motor out. Will probably shift the powerband up another 400-600rpm to 3800rpm but should gain 1500 rpm up top.
Also fitting a manlier intank fuel pump, new air intake and that 3.5" exhaust.
Oh and finally the wide arches have been fitted. Looks good  :evilgrin:
Offline Bignod00
  • Ginsters are sh*tE!!
« Reply #190 on: February 20, 2016, 06:23:04 am »
NEED pics of the new look buddy! :happy2:
Offline Gti_Mad
« Reply #191 on: February 20, 2016, 10:38:56 am »
Any pics ??
dansmith180
« Reply #192 on: February 20, 2016, 11:41:21 am »
That has to be one of the biggest teases I've ever read  :signLOL:
You got any idea what numbers you'll be expecting from this?
Offline gticc
« Reply #193 on: February 20, 2016, 07:44:00 pm »
Wow, what a weapon this is! Can't wait to see the next stage of build.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #194 on: February 21, 2016, 02:14:26 pm »
I'll be happy with 700hp but mr raymond bell from RBRE thinks once all the hardwares on it could potentially do up to 750hp.
