Author Topic: VCDS Lite Vagcom - xenon retro fit  (Read 2014 times)
Offline GTI_UK
« on: November 22, 2012, 08:40:21 am »
Hi guys,
I don't have it at the moment but wondering if the VCDS lite by Ross-Tech would allow me to change the light setting which are required following xenon retro fit?
Offline Neiltdi
  • Full Hex+CAN
Re: VCDS Lite Vagcom - xenon retro fit
« Reply #1 on: November 22, 2012, 09:32:00 am »
what kind of lead do you have?
Full Hex+CAN in Hampshire.
Offline GTI_UK
« Reply #2 on: November 22, 2012, 10:51:26 am »
It's a Cheap USB jobby from eBay...
« Reply #3 on: November 22, 2012, 11:06:44 am »
No.
Offline GTI_UK
« Reply #4 on: November 22, 2012, 11:14:01 am »
So only a original Ross-Tech cable can be used or are there other alternatives?
Also, does this module option HAVE to be changed?
« Reply #5 on: November 22, 2012, 11:16:43 am »
Yes. It has to be coded otherwise your likely to get flickering lights.
Offline graeme
« Reply #6 on: November 22, 2012, 12:19:12 pm »
yeh you need have them coded or they will just flicker on and off , you will need a real vcds cable. Im sure some one close to you on here will have one , try the vcds area on here and see ? .
Offline GTI_UK
« Reply #7 on: November 22, 2012, 12:29:01 pm »
Thanks guys. Am considering investing in a quality cable but until then.. will pop a post in the VCDS section
Offline skard
  • -Receive: 245
« Reply #8 on: November 22, 2012, 01:06:03 pm »
VCDS Lite doesn't work on mk5 platforms, even if you buy a license for the fake cable.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Re: VCDS Lite Vagcom - xenon retro fit
« Reply #9 on: November 22, 2012, 01:15:27 pm »
Where abouts are you? I can help if you're not too far. I'm in Preston,  lancs.
I did this at the weekend for another forum member.
Jas
Edit: seen your other post, you're a southerner ;)
VCDS (Preston, Lancashire)
Offline GTI_UK
« Reply #10 on: November 22, 2012, 01:25:01 pm »
Could you elaborate please? Are you saying I would need both a 'proper' cable and a different licenced software?
Jas
haha, thanks for the offer anyway Jas
« Reply #11 on: November 22, 2012, 01:26:00 pm »
You need either Hex-CAN-USB cable or a Micro CAN cable.
