Author Topic: interior fan, windscreen washer pump and 12v cig lighter not working  (Read 3539 times)
Offline tonto83
Hey guys, hope somebody can help me.
Turned on the car this morning and the windscreen washer pump isn't firing (can't even hear it), I can feel very slight heat coming from the vents but the fan/blower isn't working.  Also noticed that the 12v cigarette lighter has no power coming to it either.
Reading on-line all three seem to be operated by different fuses, is it normal that three fuses could blow at once or am I missing something?
any help/advice appreciated
Paul
Offline S2 Ant
  • -Receive: 21
Re: interior fan, windscreen washer pump and 12v cig lighter not working
« Reply #1 on: December 05, 2012, 10:22:42 am »
Will take you 2 secs to check the fuses and find out
Ant
Offline tonto83
« Reply #2 on: December 05, 2012, 01:45:02 pm »
Just checked the fuses in day light and they all seem to be ok.
Is there anything else I should be checking?
Offline marko
« Reply #3 on: December 05, 2012, 01:55:59 pm »
you checked both fuseboxes i guess...
can you do a scan???
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline tonto83
« Reply #4 on: December 05, 2012, 02:16:53 pm »
Ye I checked both boxes.  I don't have vcds so I was just checking to see if there was anything obvious before I organised a scan
Cheers,
Paul
Offline doylebros
  • -Receive: 310
« Reply #5 on: December 05, 2012, 08:40:28 pm »
In the engine compartment when you remove the fuse box cover look at the wiring tails (with the bolt fixings) and see if any are corroded!
 :driver:
Offline Statller-Stevo
« Reply #6 on: December 06, 2012, 10:37:55 am »
Iirc all these fuses have the same feed in the fusebox on the driver side of the dash, you may have a fault or blown fuse / relay on the fuse board under the bonnet. :smiley:
Offline tonto83
« Reply #7 on: December 07, 2012, 10:25:37 pm »
Thanks for help lads.  Dodgey relay was the culprit.  Mechanic had it sorted in jig time and only €10 to replace
