Author Topic: Fitting Lower Engine Mount?  (Read 3455 times)
Offline JigBake
« on: December 05, 2012, 04:58:07 pm »
Hi,
I have decided to upgrade my lower engine mount. I will be buying a Vibratechnics fast road one, but was wondering how much work it would be to fit it myself, or should I get a garage to do it? Also is it worth fitting the smaller mount on the other end as well, or should I not bother?
Cheers, Jake.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=niegqaf3m9baih6eb9c6vk4csa&/topic,19740.0.html
Re: Fitting Lower Engine Mount?
« Reply #1 on: December 05, 2012, 05:11:35 pm »
Subframe off
Old bush out
Put new bush in according to manufactures instructions.
Refit Subframe
Re-align the car.
« Reply #2 on: December 05, 2012, 06:36:00 pm »
Is the Vibratechnics lower mount like in my photo?:
^ If it's like mine, it needs a lot of force to pump it in and you'll need to remove the subframe to do it and also, importantly, renew its bolts.
Offline JigBake
« Reply #3 on: December 05, 2012, 07:03:56 pm »
Yes looks identical to yours. If thats what is involved then I will get it fitted I think. I dont fancy doing that.  Have you just had the bigger mount changed? Or did you get thd smaller one done at the front as well?
I fitted a powerflex insert but is pretty crap imho. My Milltek DP is contacting something when wheel spinning and hopping.
Cheers.
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: December 05, 2012, 07:09:54 pm »
I had a THS lower mount fitted and it cost me £40 labour for about an hours work.
« Reply #5 on: December 05, 2012, 10:32:18 pm »
Cheers.
....I first had a Powerflex insert supplied by Milltek because of this mounting breakage:
Then I had a lower engine mount followed very soon after by the other two engine mounts. Reviews and info here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,5082.0.html
http://www.mk5golfgti.co.uk/forum/index.php/topic,6086.0.html
