Author Topic: fault code and poor maf reading  (Read 2397 times)
Offline chopper
« on: December 06, 2012, 11:01:21 pm »
im running a stage 2+ golf gti edition 30, but i keep getting this fault code
1 Fault Found:
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
               P2096 - 002 - Too Lean - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 2
                    Fault Frequency: 5
                    Mileage: 109874 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:48:42
             Freeze Frame:
                    RPM: 2142 /min
                    Load: 29.8 %
                    Speed: 86.0 km/h
                    Temperature: 81.0∞C
                    Temperature: 6.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0000
Could it be an exhaust leak?
on another note i ran some 4th gear logs today and my MAF reading is only just over 210 and dropping off to 180 in high revs. I have a forge twintake... surely it should be more than this and shouldnt be dropping off?
any suggestions ?
Re: fault code and poor maf reading
« Reply #1 on: December 06, 2012, 11:06:23 pm »
I would have thought that MAF figures of around 260-270g/s are what you should be getting
Offline chopper
« Reply #2 on: December 06, 2012, 11:14:09 pm »
those of the sort of figures (260-270) i would have expected - cant understand why the forge twintake  isnt producing the goods.
« Reply #3 on: December 06, 2012, 11:15:47 pm »
Maybe the filters are in the wrong way around.  :signLOL:
What was it doing pre-twintake? What were the figures?
Offline Leach76
« Reply #4 on: December 27, 2012, 02:13:40 pm »
Ok dont want to sound stupid here incase i am missing something but why arent you looking at the part that is saying about the pre-cat lambda sensor rather than talking about the maf readings ? surely if you have a knackered oxy sensor the fuelling is not going to be correct ?
Phantom black S3,Giac stage1 & Evoms intake
