Author Topic: cruise control and camber on front wheels  (Read 1372 times)
Offline dadangerman
« on: December 10, 2012, 10:58:11 am »
hi I am after having cruise control installed in my car. does anyone know someone near me who will do it and for how much? and a number?
and also about a month ago I drove up a curb and now have camber on front passenger wheel , (top of wheel sticks out more than bottom wheel)
not by a lot but enough to cause uneven wear on my tyres and show abit more tread of tyre from above view.
what do you think I have bent?
thanks in advance
Car: 2004 1.9 tdi (105) mk5
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: cruise control and camber on front wheels
« Reply #1 on: December 10, 2012, 11:09:42 am »
Where are you located for cruise?
I would just take it to a garage as it could be anything thats bent
Offline dadangerman
« Reply #2 on: December 10, 2012, 11:12:59 am »
skelmersdale, Lancashire (sorry I thought it displayed it next to my name)
i will be having a look myself just thinking if there is anything to look other than wishbone, shock?
or if anyone has had same experience and what they had to do
thanks for reply
homesqueeze
« Reply #3 on: December 10, 2012, 07:29:04 pm »
Dealers should charge around £180 for cruise. However you will obviously get it a lot cheaper if someone local with the "know how" can do it.
Offline dadangerman
« Reply #4 on: December 12, 2012, 02:27:41 pm »
bump. anymore help?
Offline chrisr763
  • -Receive: 62
« Reply #5 on: December 12, 2012, 02:33:16 pm »
bump. anymore help?
I think your best bet would be to contact the 'people in the know' directly. I believe Squeeguk may be able to help, and i can vouch that his work is 100% top notch,. Eddie-NL is most likely the man for the job... But contact both  :happy2: Hope this helps!
This thread may help:
http://www.mk5golfgti.co.uk/forum/index.php/topic,57335.msg651934/boardseen.html#new
Also... Get the camber looked at by a garage who can adjust the alighment. They may be able to tell you the problem
« Last Edit: December 12, 2012, 03:25:34 pm by chrisr763 »
