Author Topic: 8x18 ET35 on the front of a Mk5 - Yes or no?  (Read 2976 times)
Offline Shorty
  • -Receive: 25
« on: December 17, 2012, 10:10:48 am »
Might be buying some new wheels, they are 8x18 ET35. Will this fit on the front of my car alright? From what i've seen people normally run 8's in the 40 offsets?
| Mk7 R |
Offline graeme
Re: 8x18 ET35 on the front of a Mk5 - Yes or no?
« Reply #1 on: December 17, 2012, 10:26:09 am »
probably rub like hell !
Offline SI-R32
  • -Receive: 126
Re: Re: 8x18 ET35 on the front of a Mk5 - Yes or no?
« Reply #2 on: December 17, 2012, 10:38:38 am »
No mate they'll stick massively out the arches and will Defo rub, 42 minimum, 45 good fit, 48-51 will fit like a glove as 50 or 51 is the standard offset
Offline Dannyboy88
« Reply #3 on: December 17, 2012, 11:12:47 am »
I'm running et35 8j on the front of the jetta no problem with the coilovers all the way down
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: December 17, 2012, 12:46:18 pm »
You should be just about ok
PLANS: Stage 2+
Offline Dan648v
  • -Given: 28
« Reply #5 on: December 17, 2012, 01:45:03 pm »
My summers are 18x8 et42 with a 8mm spacer making et34.
I run a 215 40 18 down low on ap coilovers and it only scrapes if you hit an unsuspecting bump/pothole
