Author Topic: RCD510 and retrofit aux in  (Read 9659 times)
Offline jonnym
  • -Given: 40
« on: December 23, 2012, 08:04:28 pm »
OK, so this is my RCD510 --->
Now I need the music on my blackberry in my life and the SD card I have at the moment simply isn't cutting it. The RCD510 was fitted when I bought the car and there is no aux input either in the glove box, centre console or in the armrest bit. So I think the RCD510 is an upgrade and my golf never actually had a aux in.
So, is my trail on thought correct? What can I do to get a aux in fitted that works with the RCD510? I'm thinking of someone to be a retrofit but before I make enquiries thought i'd ask the questions!
Forgot to say it doesn't have the sat nav, but it does have a aux touch button.
Cheers.
« Last Edit: December 23, 2012, 08:06:23 pm by jonnym »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RCD510 and retrofit aux in
« Reply #1 on: December 23, 2012, 08:10:38 pm »
it can be added
http://www.mk5golfgti.co.uk/forum/index.php/topic,36874.0.html
the 3 wires can be connected to the back of the rcd510
Cluster and Key coding
Location Great Yarmouth
Offline jonnym
  • -Given: 40
« Reply #2 on: December 23, 2012, 08:21:19 pm »
hmm, my search didn't go back far enough!
Excellent stuff thanks eddie and looks fairly simple. Just need to get the parts and find someone with VCDS!
Can I put the input anywhere else instead? I don't actually have an armrest - i called it that as I didn't want to say the centre thing!
Offline jonnym
  • -Given: 40
« Reply #3 on: December 23, 2012, 10:33:44 pm »
From doing some reading, will this install effect the 6-cd changer I have with my RCD510?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: December 23, 2012, 10:40:53 pm »
you can install an aux in without cd changer / ipod dock / mdi
Offline jonnym
  • -Given: 40
« Reply #5 on: December 23, 2012, 10:46:14 pm »
So it will work with it? I take it I can still use the CD changer (ie: the install won't disable the cd unit)
Apologies for my non-technical mindedness - its not something I have much experience with!
Thank you once again!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: December 23, 2012, 10:50:00 pm »
you can still use the built in cd changer
Offline jonnym
  • -Given: 40
« Reply #7 on: December 23, 2012, 10:52:44 pm »
Thank you! I'll give TPS a ring in the new year for costs.
Offline golfman
  • -Given: 17
« Reply #8 on: December 24, 2012, 08:49:46 am »
Why not just buy everything from Ed
He can make the looms up!!!
Scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #9 on: December 24, 2012, 09:50:45 am »
Sorry to jump on this thread, whats the cheapest / easiest way to get an ipod charger into the glovebox that will work with my rns-510? Bought a short car charger but my ash tray lid wont close with it and the cable in place.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: December 24, 2012, 09:56:02 am »
treat yourself to an MDI
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #11 on: December 24, 2012, 11:34:48 am »
Can it just be a cable in the glovebox and not the thing under the armrest?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: December 24, 2012, 12:04:44 pm »
Yes
I have both kits available
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #13 on: December 24, 2012, 12:25:12 pm »
How much for the glovebox one?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: December 24, 2012, 12:27:12 pm »
£110 Delivered
