Author Topic: Need help and Advice  (Read 4768 times)
Offline Mertyvw
« on: December 26, 2012, 08:48:22 pm »
Hi guys
Basicall i put 0w 40 oil in to my 1.9 diesel engine while it was hot, and i normally use 0w 30 . i turned the ignition and it wouldnt fire up and it wudnt start properly until i put ma foot down on the accelrator a few times. And then i got the engjne management light on and the glow plug light flashing
And now after a couple of drives it all got back in to its normal running condition , ma local vw specialist open/ back  on 2nd  jan and im driving to Germany this sunday . Can some one advise me oj whether everyhting is ok and its back to normal or shall i take it in to a garage.
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
Offline bacillus
  • -Receive: 453
Re: Need help and Advice
« Reply #1 on: December 26, 2012, 10:11:25 pm »
IMO just topping up with a different viscosity oil shouldn't cause a warning light to come on.
Have you checked your rear brake lights to see if you have a blown bulb?
If you intend to go to Germany at the weekend then look in the vcds form for someone with a vcds cable to scan your car to find out what the fault is/was.
Offline Mertyvw
« Reply #2 on: December 26, 2012, 10:28:12 pm »
Thanks for that and now again the flow plug error light is flashing damn this car
Offline Matto
  • -Receive: 116
« Reply #3 on: December 26, 2012, 10:35:41 pm »
Could really do with getting it scanned. Just out of interest, do you have cruise fitted?
Offline Mertyvw
« Reply #4 on: December 26, 2012, 11:17:19 pm »
Yes retrofitted
Offline Mertyvw
« Reply #5 on: December 26, 2012, 11:24:08 pm »
The flashing light comes back when the car is rolling on cruise control. And i cant use cruise control white the flashing light is on. Has this got something to do with the cruise control?
Offline Matto
  • -Receive: 116
« Reply #6 on: December 26, 2012, 11:52:58 pm »
I'm only thinking back to when I saw this light on my mk4. The cruise wouldn't work as in I couldn't set it to sit at any speed. It turned out to be the brake pedal switch. There is also one for the clutch. These are tied into the cruise control for safety purposes.
Offline Neiltdi
  • Full Hex+CAN
« Reply #7 on: December 27, 2012, 09:24:20 am »
Had this on my mk5 , i fitted a new brake pedal switch and its been fine ever since
Full Hex+CAN in Hampshire.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: December 27, 2012, 09:50:47 am »
if the engine has a major fault then cruise won't work, get it scanned to see what shows up
Cluster and Key coding
Location Great Yarmouth
Offline W8 Performance
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
« Reply #9 on: December 27, 2012, 12:01:56 pm »
Fabia VRS's have a similar issue too (1.9td) and as said above it is sometimes linked to the brake lights and pedal switch. Where are you based?
Offline Mertyvw
« Reply #10 on: December 27, 2012, 12:29:32 pm »
Richwig83 will be doing a scan on it later today we'll keep u posted
« Reply #11 on: December 27, 2012, 05:51:51 pm »
1 Fault Found:
16706 - Engine Speed Sensor (G28)
            P0322 - 000 - No Signal - Intermittent
             Freeze Frame:
                    RPM: 1428 /min
                    Torque: 202.0 Nm
                    Speed: 22.0 km/h
                    Load: 0.0 %
                    Voltage: 14.59 V
                    Bin. Bits: 00001000
                    Idle Stabilization: 0.0°KW
                    RPM: 756 /min
Readiness: 0 1 0 0 0
Offline Mertyvw
« Reply #12 on: December 27, 2012, 07:37:07 pm »
Im in north london . And thanks to Rich wig. For the scan .
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: December 27, 2012, 07:40:23 pm »
http://wiki.ross-tech.com/wiki/index.php/16706/P0322/000802
probably a good idea to get it sorted before you head off to Germany
Offline Mertyvw
« Reply #14 on: December 27, 2012, 08:39:02 pm »
Thanks or the advice and link Ed the symptoms are the ones im getting now.
Does anybody have rough idea of the cost for the part + labour ???
