Author Topic: Would a boken engine cover like this effect performance?  (Read 1947 times)
Offline holepunch
« on: January 05, 2013, 02:24:21 pm »
I've just successfully replaced my PCV valve however I noticed that the underside of my engine cover is broken.  As it contains the air filter will a hole in this location cause a problem?  If yes any ideas how much a replacement engine cover costs?
Thanks in advance.
Offline zerolag
  • Ass of Ennis
Re: Would a boken engine cover like this effect performance?
« Reply #1 on: January 05, 2013, 02:53:47 pm »
I very much doubt that will make any difference. Replacement covers are very expensive, at which point its probably worth while getting an aftermarket CAI.
Offline Bane
  • "I was born a handsome man and now I'm half a goat
« Reply #2 on: January 05, 2013, 02:56:34 pm »
*COUGH* ducttape*COUGH*
 :grin:
« Reply #3 on: January 05, 2013, 03:05:40 pm »
The air goes through the filter box on its way onwards, so I would say that any hole in the filter box is neither good for performance nor for stopping unwanted debris.
I advise that you duck-tape it immediately until you decide what other option to choose.
« Last Edit: January 05, 2013, 04:30:47 pm by RedRobin »
« Reply #4 on: January 05, 2013, 04:07:23 pm »
It will only affect performance if it is after the MAF.
Duck Tape FTW!
Offline martziniuk
« Reply #5 on: January 05, 2013, 08:04:25 pm »
I don't think that crack is even in the air intake tract, so it should have no effect on performance.
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
