Author Topic: Mk6 reverse camera issue  (Read 3568 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« on: January 07, 2013, 10:56:27 am »
Have an intermittent problem with the boot badge.
I'd say 1 out of every 5 times the boot badge doesn't close properly.
The camera closes and pulls in ok but the mechanism doesn't close and is left a jar.
Anyone else had this issue and know of a fix?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Mk6 reverse camera issue
« Reply #1 on: January 07, 2013, 07:16:52 pm »
Anyone?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: January 08, 2013, 02:24:12 pm »
where did you get it from?
who fitted it?
Cluster and Key coding
Location Great Yarmouth
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: January 08, 2013, 03:25:50 pm »
I bought it off DonalM, he got it from SteveP a few months back.
I did the fitting, using Steve's how to.
Worked perfect for the first couple of months, now is sticking open  :sad1:
You come across this before?
Funny enough I saw a passat today in the car park with the same issue, badge a jar, wondering if this common enough problem?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: January 08, 2013, 08:37:09 pm »
Any ideas anyone?
Offline SI-R32
  • -Receive: 126
« Reply #5 on: January 08, 2013, 08:47:36 pm »
take the unit apart and test just the mechanism over and over, make sure its all greased up and make sure nothing is broken or damaged
this isn't a how to but there are some pics on here that may help you
http://www.r32oc.com/topic/39043-broken-reverse-camera/
Offline SI-R32
  • -Receive: 126
« Reply #6 on: January 08, 2013, 08:52:45 pm »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: January 08, 2013, 10:22:33 pm »
Thanks for that SI-R32, what grease would you recommend using?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #8 on: January 28, 2013, 09:51:52 am »
Well thought I'd update this and wouldn't you know since first posting this problem not once has it happened  :confused:
Happy days, just hope I haven't jinked myself now  :signLOL:
Offline doylebros
  • -Receive: 310
« Reply #9 on: January 29, 2013, 05:29:00 pm »
Could it of been an issue with the current minus temperatures - ice - and locks don't mix to well!
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #10 on: January 30, 2013, 10:44:35 pm »
No ice here in the very south of Ireland  :jumpmove:, barely dropped below 7 degrees for more than a couple of days.
Got a feeling it was the piggyback fuse holder, it was fully pushed in but gave it a little wiggle for good measure and hey ho
