Author Topic: ITG Maxogen k04 bung  (Read 2143 times)
Offline GOLDENBOY
  • -Given: 17
« on: January 14, 2013, 08:35:47 pm »
I have bought a itg maxogen induction kit a while ago now,  its time to get it on now for a remap, itg maxogen  kit i have bought is for k03 turbo,  I need the bung so it will fit edition 30 k04 turbo any body know where I can buy the bung from, awesome gti out of stock!!! :sad1:
Candy white edition 30 / Revo stage 1 / Itg maxogen / xenons/ R32 brakes front/rear/ H&r springs / cruise/ open fogs/ Rns-510
Offline GarethB
Re: ITG Maxogen k04 bung
« Reply #1 on: January 14, 2013, 09:52:25 pm »
I purchased mine from revotec - was about £25.
I'm sure that there is a link on here somewhere....
Offline Marshall
« Reply #2 on: January 14, 2013, 11:50:52 pm »
This is the part you need.
I bought mine from here and delivery was next day.
http://www.ebay.co.uk/itm/290773478813
MISANO RED RS3
Offline edd666999
  • -Receive: 89
« Reply #3 on: January 15, 2013, 01:13:14 am »
If you bought a KO3 kit, then this doesn't have a outlet for the DV meaning it wont need a bung.
If you have bought the k04 kit then it will need a bung to fit a k03 car.
If you have an edition 30 and have a k03 kit you need to replace the entire elbow that goes from the turbo to the maf.
k04 (notice the metal bit sticking out the elbow):
k03 (no metal sticking out the elbow)
Offline GOLDENBOY
  • -Given: 17
« Reply #4 on: January 15, 2013, 06:42:03 am »
Thanks guys, just purchased the bung from ebay, i will get the hose drilled and bung in the weekend.  :happy2: has anybody else done this recently??? is this all i need make this work from K03 kit to K04 turbo.
« Last Edit: January 15, 2013, 06:45:48 am by GOLDENBOY »
Offline Marshall
« Reply #5 on: January 15, 2013, 08:26:41 am »
Yeah that's the only difference between k04 and k03
My tip for doing it would be wrap your silicone pipe in masking tape then fit the kit in place first (doesn't need to be secured) then mark the spot where the bung should be.
Then remove and cut with a sharp knife.
If you cut a small X then once you've pushed the bung through trim off the excess.
I done my bcs kit a few weeks ago and it works perfectly.
MISANO RED RS3
Offline GOLDENBOY
  • -Given: 17
« Reply #6 on: January 15, 2013, 11:21:35 am »
Thanks again Marshall!!!!  :happy2:
Offline muckipup
  • -Receive: 25
« Reply #7 on: January 15, 2013, 02:34:49 pm »
The eBay kit contains a hole punch  :happy2:
Offline Marshall
« Reply #8 on: January 15, 2013, 02:57:52 pm »
On the itg its the silicone pipe that takes the bung.
MISANO RED RS3
