Author Topic: How Do I Remove the Rear Light Cluster?  (Read 4786 times)
Offline t20lau
    • Website design Sheffield
« on: January 15, 2013, 02:14:43 pm »
Hi Guys,
I've searched around but struggling to find an answer...
I was wondering if and how I can replace the rear cluster this is attached to the boot lid?!
Just to make this clear, I have got this far...
Thanks,
Tom
SEAT Ibiza Sport | Vauxhall Astra VXR | BMW Z4 M-Sport | VW Golf GTi Edition 30 | BMW F30 330D X-Drive
Offline brough74
Re: How Do I Remove the Rear Light Cluster?
« Reply #1 on: January 15, 2013, 02:19:53 pm »
You need to remove the boot panel on the inside of the boot, and then you will see the bolts you need to undo.
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Offline gazon69
« Reply #2 on: January 15, 2013, 02:21:16 pm »
Open boot lid and look where the remaining light is from the inside. There is a small cover over it which pops off. Inside there are 2 nuts . 1 is tricky to get to. Take off the 2 nuts and the light should just pull away from the boot lid.
Offline t20lau
« Reply #3 on: January 15, 2013, 02:22:35 pm »
Thanks for the info! I'll give it a shot later tonight!!!
Offline bacillus
  • -Receive: 453
« Reply #4 on: January 15, 2013, 03:21:25 pm »
Just don't drop those nuts!  :scared:
I found if you get someone to hold the boot open so that the lights are parallel to the floor, if you happen to drop a nut it should still be retrievable.
Offline Kalpsn2000
  • -Receive: 56
« Reply #5 on: January 15, 2013, 04:21:55 pm »
Yes you have to be careful. One of the bolts is tricky to get to and can be easily dropped.
Offline t20lau
« Reply #6 on: January 15, 2013, 05:17:20 pm »
hahaha! I'm so going to drop the bolts...
