Author Topic: Xenon main beam doesn't stay on.  (Read 7734 times)
Offline screech
« on: January 19, 2013, 08:15:55 pm »
Hey guys.
Finally got round to fitting my Xenons today, complete with shutters and levelling.
Everything is working except one shutter, which should just be a connection.
But the one that does work, when I put on main beam, flicks on, but flicks back off after a few seconds, the blue dash light stays on.....
Any ideas?
Offline bacillus
  • -Receive: 453
Re: Xenon main beam doesn't stay on.
« Reply #1 on: January 19, 2013, 11:38:46 pm »
It may need coding.
Offline marko
« Reply #2 on: January 19, 2013, 11:40:44 pm »
using right pin in cecm??
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline nikeboyuk
« Reply #3 on: January 25, 2013, 04:36:49 pm »
I'm guessing this is OEM, have you tried to get a VCDS scan and see if any controller is not working correctly?
Offline vrod
« Reply #4 on: February 15, 2013, 08:02:07 pm »
hey guys i wanna raise this thread as it's relevant for my situation..
I have just retrofitted bi-xenons for my golf plus but i cannot get the high beam to work, the shutter simply doesnt kick in. i have measured the power with a voltmeter but it returns 0.00 volts, absolutely nothing. :(
I have checked all wirings and everything is set and wired as it should. i have also coded everything right. The right high beam used to work about 2-5 seconds each time i switched it on but it doesnt work at all now, after i have put in a new afs module in the headlight cause the old module was defective.
Anyone knows something? Here's the status of the CECM:
Code: [Select]
Friday,15,February,2013,16:12:46:16946
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
                Address 09: Cent. Elect.       Labels: 3C0-937-049-23-H.LBL
Control Module Part Number: 3C0 937 049 E    HW: 3C0 937 049 E
  Component and/or Version: Bordnetz-SG     H37 1002
           Software Coding: AB8B8F2700041800000A00000F000000000B5D035C
            Work Shop Code: WSC 12345 785 00200
           Additional Info: 5M0955119B  Wischer 041106 020  0501
                      VCID: 2B55C23A8A470240A4E
3 Faults Found:
02394 - Parking Light Left Front (M1)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 88381 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02498 - Left Low Beam Reflector Motor (V294)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 88381 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02499 - Right Low Beam Reflector Motor (V295)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 88381 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Offline doylebros
  • -Receive: 310
« Reply #5 on: February 15, 2013, 08:15:55 pm »
This is worth a read if your stuck,
http://www.myturbodiesel.com/1000q/a5/HID-retrofit-Jetta-a5.htm
Hope it helps.
Offline vrod
« Reply #6 on: February 15, 2013, 09:19:08 pm »
Thanks mate, i can see that there is a issue where the plug which goes into the CECM can be fully locked while the wires are not fully inserted which can result in no electrical contact.. I will take a look at that :)
Offline doylebros
  • -Receive: 310
« Reply #7 on: February 15, 2013, 09:24:37 pm »
Also double check the coding has changed after changing it - plenty been caught out with that error !
Offline vrod
« Reply #8 on: February 15, 2013, 09:29:52 pm »
can you specify that? Check if the coding has applied? Does that mean i have to open the long coding helper just after i have applied the code or should i switch ign off and then on and have a look?
Offline doylebros
  • -Receive: 310
« Reply #9 on: February 15, 2013, 09:33:33 pm »
I do as you said - switch the ignition off then recheck - its those simple mistakes which cause loss of hair!
Keep the thread going if you sort it as there's been plenty problems with this mod!
Offline vrod
« Reply #10 on: February 16, 2013, 01:34:04 pm »
I tried to check the Bi-xenon wires today. The one in D6 didnt really "catch on" but i managed to bend it a little inside so it could get contact. A5 was fine. Turned on the vehicle but no luck this time either... Checked code, everything were as it should be. Damnit.
When i try to go to the central electronics in VCDS and then do a output test on the high beam it reports "Refused by control module"... could this be software related?
Offline doylebros
  • -Receive: 310
« Reply #11 on: February 16, 2013, 05:07:49 pm »
Since I've never undertaken this mod I can only share data I've came across.
I had looked at this link and thought it could be helpful!
http://furmanka.blogspot.co.uk/2007/12/mk5-wiata-ksenonowe-z-samopoziomowaniem.html
Let's know what you think.
Offline vrod
« Reply #12 on: February 17, 2013, 09:00:01 am »
Thanks for the link. Unfortunately it's not useful in this matter since it's just the same guide as the others.  :/
Offline Steviedubs
« Reply #13 on: February 17, 2013, 01:31:53 pm »
I may be talking out me arse here but don't you need to tell the car it has xenons fitted in the can gateway installation list?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Xenon main beam doesn't stay on.
« Reply #14 on: February 17, 2013, 03:40:03 pm »
Have you activated xenons in vcds?
Jas
VCDS (Preston, Lancashire)
