Author Topic: Removed ITG Now It Keeps Cutting/Erratic Idle  (Read 2963 times)
Offline Adam_
« on: January 20, 2013, 08:53:36 pm »
Hi there got a bit of a problem I need sorted ASAP.
I have recently removed my ITG induction and put my standard air box on. The problem is it now won't idle and is very erratic so much so it stalls. Disconnecting the MAF sorts it out. Now for the confusing thing,
I popped the ITG back on and it's fine? Runs as it should. I have removed the battery for a day to try and see if it resets the ECU's expectations to no avail. The ECU is remapped :sad1:
Fault code is:
17497 - Mixture Regulation; Bank 2; Range 1
P1089 - 001 - Lean Limit Exceeded
Thanks in advance.
Offline Russ_leeds
Re: Removed ITG Now It Keeps Cutting/Erratic Idle
« Reply #1 on: January 20, 2013, 09:17:31 pm »
faulty/damaged maf housing on the standard air box?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline Adam_
« Reply #2 on: January 20, 2013, 09:40:00 pm »
All pipes and housing checked and its all in order with no cracks or leaks.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #3 on: January 20, 2013, 09:48:50 pm »
If it worked fine with the ITG both times, then the ECU needs to adapt to the OEM air box. When swapping back, drive it gently for a while and build the power on gently after a good few miles so it doesnt run lean.
Offline Adam_
« Reply #4 on: January 20, 2013, 10:10:48 pm »
It wont get out of the garage without stalling :-(
Offline samdem
« Reply #5 on: January 20, 2013, 10:13:54 pm »
just let it idle in your garage for a while and then take it out for a little bit
Offline 56OctyVRS
  • -Receive: 72
« Reply #6 on: January 21, 2013, 10:06:21 am »
Have you  checked to see whether the seal is on the maf sensor and not fallen off when removing it from the itg
« Reply #7 on: January 21, 2013, 11:29:13 am »
Try resetting the fuel trims.
Offline Adam_
« Reply #8 on: January 21, 2013, 12:08:10 pm »
How do I do this?
I presume via vagcom? Mine is playing up :-(
Offline bacillus
  • -Receive: 453
« Reply #9 on: January 21, 2013, 12:58:30 pm »
That's unlikely to make any difference. And yes, you need vcds to reset the trim measurement.
Offline chungster
« Reply #10 on: January 21, 2013, 02:14:26 pm »
Check the OEM air box that nothing is blocked in there
Offline Adam_
« Reply #11 on: January 21, 2013, 06:56:45 pm »
Nothing is blocked, and no vac leaks  :confused:
