Author Topic: Canbus gateway - Will mine work?  (Read 10762 times)
Offline tomanni
« on: January 23, 2013, 12:42:22 pm »
Hi all,
Having scoured the search function for my answer, I have been driven to making a post with my question!
I have a 2007 Edition 30 with an RCD300 currently fitted. I want to fit an RCD510 but am aware there may be a battery drain issue due to the age of my car.
I went to VW yesterday to establish which Canbus gateway was originally supplied on my car and they told me it was '7NO 907 530 H'
Having looked through the posts where Eddie_NL is selling his Canbus gateways which solve the issue, I have seen that his part numbers are the same as mine, but with a 'C' at the end - going against the golden rule of newer than 'L' will work.
The usual replacements seem to have '1KO' at the start of the part number, whereas mine does not...
Can someone shed any light on the issue? Will I need a newer revision or have VW told me the newest part available?
Thanks :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Canbus gateway - Will mine work?
« Reply #1 on: January 23, 2013, 12:50:41 pm »
Your gateway won't be 7N0 907 530H
it probably is 1K0 907 530H, K or L
if it is H and some K it will drain
I would suggest that you first find out the actual part number and go from there (examination or a Scan will sort that)
If you do need a new one, i can supply
Cluster and Key coding
Location Great Yarmouth
Offline tomanni
« Reply #2 on: January 23, 2013, 12:57:37 pm »
Thanks for the quick reply Eddie  :smiley:
I will have a look tonight - if I need a new one coding, what info do I need to supply to you? I have no access to VCDS unfortunately...
Offline skard
  • -Receive: 245
« Reply #3 on: January 23, 2013, 12:59:50 pm »
This is not conclusive but my January 2007 ED30 came with 1K0907530K, and the software revision that suffers from drain.
I put a later gateway in as it's easy to do.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: January 23, 2013, 01:59:13 pm »
get your post count up and PM me if you need one, you may be ok
Offline tomanni
« Reply #5 on: January 23, 2013, 02:07:28 pm »
Thanks Eddie, will do.
SKARD - That's some useful info, I think mine is a March build, so I could be lucky
Offline skard
  • -Receive: 245
« Reply #6 on: January 23, 2013, 02:12:27 pm »
I also have a March 2007 SEAT Altea with the same version of the K gateway - you could always remove it and check what's stamped on it if there's no VCDS access.
Offline marko
« Reply #7 on: January 23, 2013, 02:13:34 pm »
my car is 07 also and has the K gateway but going to change mine to the 7N0 that eddie is selling anyway
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline tomanni
« Reply #8 on: January 29, 2013, 09:29:01 am »
While I was at Statllers yesterday I asked them to read my canbus gateway version and its on revision 'k'.
I've heard there's a way of updating the software on it if it's on such a revision - is this true?
Offline torque777
Re: Re: Canbus gateway - Will mine work?
« Reply #9 on: January 29, 2013, 11:49:09 am »
My car is a sept 2007 on 57 plate with 08 build chassis , and I dropped a rcd510 in with no battery drain issues , ive been told from sometime in 07 cars started coming with can gateways that dont cause battery drain , so our 56 plate jetta wont be so lucky
sent using my own fingers
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #10 on: May 20, 2013, 05:24:18 pm »
Sorry to drag up / tag on to an old thread - I think my car has the canbus gateway which is ok for use with an RNS without causing drain - it's the 'L' version that was talked about earlier (1K0907530L) - will this be ok with an RNS510 version H?
Cheers,
Dave
Edition 30 - no. 1387
Offline skard
  • -Receive: 245
« Reply #11 on: May 20, 2013, 07:03:40 pm »
L is good, K is iffy
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #12 on: May 20, 2013, 08:33:14 pm »
Many thanks - hoped that was the case!
Offline edd30
Re: Canbus gateway - Will mine work? 1K0907530K
« Reply #13 on: November 13, 2014, 01:55:52 pm »
Iffy as in definitely end up with a battery drain problem?
Or may be ?
« Last Edit: November 13, 2014, 02:04:39 pm by edd30 »
Offline skard
  • -Receive: 245
« Reply #14 on: November 13, 2014, 01:58:27 pm »
Iffy as in there are three software versions of K, two have drain and one doesn't, best avoided. They are so cheap now for new ones.
