Author Topic: Best oil cap?  (Read 5255 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Best oil cap?
« on: January 25, 2013, 10:58:28 pm »
I wanna replace my oil cap... Whats the best one to go for? Latest revision?
Thanks,
Dom
Diesel Daily Hack.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Best oil cap?
« Reply #1 on: January 25, 2013, 11:01:40 pm »
Thanks,
Dom
I've always found the one the car came with does the job  :grin:
Has VW even revised it?
Offline woky
Re: Best oil cap?
« Reply #2 on: January 25, 2013, 11:09:48 pm »
i wanna change my brake fluid cap. Is there a new revision?   :signLOL:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Best oil cap?
« Reply #3 on: January 25, 2013, 11:35:18 pm »
Bunch of piss takers!,,,,,,,,
All I want is a new oil cap,,,,,,,,, mine is part number 06C 103 485 T, just wanted to confirm this is still current,,,,,,,,,
Thanks,,,,,,,,,,,,,,,
Diesel Daily Hack.
Offline chrisr763
  • -Receive: 62
Re: Best oil cap?
« Reply #4 on: January 26, 2013, 12:11:03 am »
People change from standard to the R8 cap am i correct?  :ashamed:
Offline Kalpsn2000
  • -Receive: 56
Re: Best oil cap?
« Reply #5 on: January 26, 2013, 12:49:23 am »
If you are going to change yours may as well go for the R8 cap as Chris mentions :happy2:
Re: Best oil cap?
« Reply #6 on: January 26, 2013, 12:53:13 am »
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Best oil cap?
« Reply #7 on: January 26, 2013, 05:57:22 am »
Is the r8 cap a split design like the original?  I've seen many posts about missing oil cap tops, I've had this too... Not sure if it catches on the bonnet fire lining or its heat expanding it off... Hasn't happened since the summer come to think of it, but keep a spare in the glovebox just in case.
Offline richtung
  • -Receive: 56
Re: Best oil cap?
« Reply #8 on: January 26, 2013, 07:34:40 am »
I believe you have to split the R8 cap and re-seat it at a slight angle in order for it to sit "flat" when screwed in to the mk5 engine. This is the reason why some people have found their expensive R8 caps missing the top section after a while!
Thanks,
Dom
Not sure of the latest revision for the OEM cap but i purchased a replacement cap from the dealers in Dec 2011 and the part number was 06C 103 485 P and the price was £5.36 exc VAT
hope this helps
Rich
Offline camfollower
  • -Receive: 31
Re: Best oil cap?
« Reply #9 on: January 26, 2013, 07:42:48 am »
Cheers for that explanation, didn't know that about the r8 cap ... Although my issue with a missing top section was on the standard one... They are cheap enough ... Wouldn't want that happening on a 25 quid r8 cap tho.
Re: Best oil cap?
« Reply #10 on: January 26, 2013, 08:10:48 am »
R8 or 911 caps fit and look a little nicer.
The problem with the oem cap outer part being pulled off is when the engine is under load on the OEM engine mounts there is so much movement in the engine, as if rocks back and forth the cap is pulled off by the engine cover.
**Edit**
R8 oil and Coolant caps Dom
*Edit again* I miss those wheels
« Last Edit: January 26, 2013, 08:16:25 am by Tfsi_Mike »
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Best oil cap?
« Reply #11 on: January 26, 2013, 08:27:31 am »
You're not running a dbilas intake are you mike? Get it swapped over for that Revo one like Alex!
I'm not sure I want a bling one, would rather have just a new oem one or maybe one from the latest Golf R...? Anyone know latest part numbers?
Thanks for all the replies  :P
Diesel Daily Hack.
Re: Best oil cap?
« Reply #12 on: January 26, 2013, 08:32:59 am »
Am I hell, Ive had several intakes, Dom.  Keep up.  Im on the Maxogen at the minute.
Re: Best oil cap?
« Reply #13 on: January 26, 2013, 08:35:04 am »
I wouldnt say the R8 was 'bling' looks OEM+ to me.  I doubt you'll need the PN if you ring VW and say 2010 Golf R oil cap?
Offline GTI5
Re: Best oil cap?
« Reply #14 on: January 26, 2013, 08:46:33 am »
My standard cap split in two meaning i needed to use pliers to twist it off as I couldn't get any purchase on it without the handle.
Both caps seem susceptible to a certain degree, cold conditions seize the cap in place so when you go to twist it you twist the top half off and not the rest of it!
Now got an R8 cap on, at least the cover over the handle should last longer.
« Last Edit: January 26, 2013, 08:50:12 am by GTI5 »
MK6 GTI Revo
MK5 GTI DSG - Gone
