Author Topic: Can someone do me a quick favour!?  (Read 1955 times)
Offline CMB
« on: January 29, 2013, 12:55:29 am »
I have an 06 GTI and when I press the brake pedal in when stationary the ESP light flashes for like 15 seconds. Can someone go into there GTI start it up and press the bake in and see if it does the same. If that's not normal does anyone have any idea why it's doing that?
Offline ell.s
Re: Can someone do me a quick favour!?
« Reply #1 on: January 29, 2013, 05:01:06 am »
Mine certainly doesn't, can't help on why though sorry dude!
« Reply #2 on: January 29, 2013, 08:11:48 am »
ABS pump faulty?
Offline Manney
« Reply #3 on: January 29, 2013, 10:18:08 am »
Or ABS rings in the back discs faulty/corroded?
Offline CMB
« Reply #4 on: January 29, 2013, 02:11:07 pm »
Thanks for the replies, does anyone know if or how i can check if its the ABS rings or sensor myself? Sounds like it could be an expensive fix if its the ABS pump
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #5 on: January 29, 2013, 02:16:50 pm »
Low brake pads?
Diesel Daily Hack.
Offline CMB
« Reply #6 on: January 29, 2013, 04:24:54 pm »
Wish it was the brake pads but i changed them and it didn't work
Offline doylebros
  • -Receive: 310
« Reply #7 on: January 29, 2013, 06:44:08 pm »
Start win a scan or your not going to make progress - check for VCDS owner in your area.
Offline r32son
« Reply #8 on: January 29, 2013, 07:06:05 pm »
As above, start with getting your car scanned.
Offline CMB
« Reply #9 on: January 30, 2013, 12:30:04 am »
Yeah just VW are wanting £90 just to diagnose it and there's no VAG-COM users anywhere near me or VAG specialists. Guess I'll have to fork out the 90 bats
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #10 on: January 30, 2013, 12:36:57 am »
For that money eBay is your friend :wink:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Can someone do me a quick favour!?
« Reply #11 on: January 30, 2013, 12:43:16 am »
Im about an hour away if you fancy a drive?
Jas
VCDS (Preston, Lancashire)
Offline CMB
« Reply #12 on: January 30, 2013, 05:21:36 pm »
Not much point in me buying the cable as i can't run the software as i have a macbook. Might take you up on that offer Jas, will try some other forums to see if i can find anyone closer first, thanks for the offer
Offline doylebros
  • -Receive: 310
« Reply #13 on: January 30, 2013, 06:55:42 pm »
If the code comes back as G201 then look for an foc repair off the dealer - see previous posts on here!
