Author Topic: ITG MAF housing size vs Standard airbox MAF housing size..  (Read 4187 times)
Offline Shorty
  • -Receive: 25
« on: January 29, 2013, 07:43:24 am »
As above, does anyone know off the top of their head the size of the MAF housing used on an ITG?
Is it 3"? I'd measure on my car but can't get to it at the mo.
Just trying to work something out, if it is 3" then that's quite a bit larger than the standard airbox size MAF housing, meaning the MAF would be out and not read correctly..
| Mk7 R |
Re: ITG MAF housing size vs Standard airbox MAF housing size..
« Reply #1 on: January 29, 2013, 08:06:22 am »
it is a stock size MAF housing on the ITG. The only non stock maf intake I know of is the VF Engineering one. :smiley:
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: January 29, 2013, 08:21:28 am »
Its 2.75 inch iirc.
Follow AKS tuning on Facebook
Offline Shorty
  • -Receive: 25
« Reply #3 on: January 29, 2013, 08:30:51 am »
If its 2.75" then that's 25% bigger than standard, so quite a difference!
| Mk7 R |
Offline bacillus
  • -Receive: 453
« Reply #4 on: January 29, 2013, 08:40:42 am »
I also think the itg maf housing has approximately the same cross-sectional area as the stock one. If you look at the fuel trim values for alot of folk on here, they are usually close to zero.
Are you having an issue seeing that you had recently bought a new maf?
Offline Shorty
  • -Receive: 25
« Reply #5 on: January 29, 2013, 09:43:33 am »
At what state of tune are the trims ok? Would it not be fairly ok on standard but then at more boost, say stage 2+ the trims would be higher because of more air? My friend is custom mapping my car and at high boost it's backing everything off because its running out of fuel.
We originally thought it was the MAF but the same with a new MAF, hence why I am selling the new one.
If you look the standard airbox housing is an oval shape which is 3" x 2" and if the ITG is 2.75" then that works out at 25% bigger which is the difference we are seeing, so would make sense.
| Mk7 R |
Offline bacillus
  • -Receive: 453
« Reply #6 on: January 29, 2013, 09:54:17 am »
Has you logged your lpfp rail pressure as being able to supply the required fuel?
Offline Shorty
  • -Receive: 25
« Reply #7 on: January 29, 2013, 10:08:37 am »
Yeah rail pressure is fine...
| Mk7 R |
Offline bacillus
  • -Receive: 453
« Reply #8 on: January 29, 2013, 03:29:38 pm »
But was the LPFP actually logged?
The higher tuned cars can stress the LPFP and cause it to starve the fuel rail of fuel if it's output is sub-optimal.
Also are you using an uprated hpfp and is your cam follower in good condition?
« Last Edit: January 29, 2013, 03:31:10 pm by bacillus »
Offline Shorty
  • -Receive: 25
« Reply #9 on: January 29, 2013, 03:53:58 pm »
Yeah I have Autotech internals and the follower has done around 3,000 miles. Rail pressure is deffo there it's just the air side of things. It's fine at 1.5 it's just we want to run more..
Going to have a look at re calibrating the MAF and going from there.
| Mk7 R |
« Reply #10 on: January 29, 2013, 05:04:49 pm »
I thought the MAF housing had to be the same as OEM? Otherwise running into scaling issues
« Reply #11 on: January 29, 2013, 08:18:03 pm »
Yes you are right Rich. Up to a certain point the ECU can adapt using the fuel trims, but once you get past that point it needs to be MAF scaled. GIAC extreme maps use MAF scaling and it is why I'm changing my intake from Evoms to VF.
 :smiley:
Offline Shorty
  • -Receive: 25
« Reply #12 on: January 29, 2013, 09:30:18 pm »
 :smiley:
This sounds about right, the ECU can adjust it but only upto a certain amount of boost by the looks of it.
By the looks of it most normal stage 2+ set ups can deal with it, it's when you go that little bit further that it becomes a problem...
| Mk7 R |
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: January 29, 2013, 09:36:32 pm »
Sounds like the low pressure fuel pump inside the tank cant cope.   Log block 231 and see if its dropping below 4 bar.  If so then give me a call for an uprated pump.  The itg wont be the issue.  Run that kit with 1.9 bar peak and 1.7 hold with no issues.
Offline bacillus
  • -Receive: 453
« Reply #14 on: January 29, 2013, 10:34:21 pm »
Alex what sort of money are we talking about for an uprated lpfp?
Is block 103 measuring the same parameters as block 231 for low-side feed pressure from the tank?
« Last Edit: January 29, 2013, 10:37:21 pm by bacillus »
