Author Topic: Fuel filters what is standard 2006  (Read 1358 times)
Offline olufsen
« on: January 29, 2013, 10:31:11 am »
Offline olufsen
Re: Fuel filters what is standard 2006
« Reply #1 on: January 29, 2013, 10:44:57 am »
Could be drivers side rear was looking at American how to.  Anyone done this?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #2 on: January 29, 2013, 12:37:18 pm »
I had my local garage do it (cost around £25) as I didnt want petrol all over my driveway.
I bought the part from VW which was around £25 IIRC
It is drivers side  :happy2:
Offline olufsen
« Reply #3 on: January 29, 2013, 12:48:27 pm »
Cheers, probably right regarding fuel; just like to get my hands in, was thinking of doing cam follower too... but again fuel related, hmm, might be worth letting the garage do the lot... defeated before I start. :lol
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #4 on: January 29, 2013, 01:23:40 pm »
Give it a go.
What's the worst that could happen?
'07 Red manual
Offline Baz300
« Reply #5 on: January 29, 2013, 05:44:06 pm »
It is really easy to change.
Get a basin under the filter and wear some latex gloves if you are worried about fuel spillage.
Just make sure you note what pipes go where before you remove them so you get them back in the correct way round.
Offline doylebros
  • -Receive: 310
« Reply #6 on: January 29, 2013, 07:05:18 pm »
Copied this from another site - can't remember where so credit to the Author is not possible (apologies)
1. Jack the rear of the car up and support it on axle stands ensuring the front wheels are chocked
2.Remove the fuel pump fuse.
3.Start the engine and if it wont start you have successfully depressurised the system. If it does start, let it run until it has stopped.
4.The fuel filter is situated underneath the fuel tank at the rear of the car (its on the back of the tank)
5. Remove the screw from the retaining clamp
6. You need to remove the pipes, noting first the direction of the arrow on the fuel filter. This can be done by pressing the tabs on the connections together and popping the connections off, or alternatively levering a large screwdriver underneath the lip of the connections to make them 'pop' off. Recommend you get a large rag to catch the fuel that spills out - there will still be a little pressure in the pipes so just be careful and dont be alarmed if you get fuel coming out the pipes for a few seconds.
7. Fit the new filter into position, and 'click' the pipes back onto the filter ensuring that you have put it with the arrow facing the same way as the old filter.
8. Reinstall the fuel pump fuse then with the drivers side door open turn the ignition on and off 3 times to prime the filter and then start the engine. It may take a few seconds to start as the lines repressurise. Let it run for a few minutes while you check the connections on the fuel filter to ensure there are no leaks
9. Lower the car and youre done!
Note:- take care not to damage the connection pipe ends as there not sold separately also keep in mind what type of light your using !!!!!!!
Offline olufsen
« Reply #7 on: January 29, 2013, 07:25:11 pm »
Cheers guys very helpful info :happy2:
