Author Topic: Disconnecting the battery - problems?  (Read 3634 times)
Offline OSB
  • -Given: 32
« on: February 03, 2013, 11:06:33 am »
If I disconnect the battery are there any potential problems or issues? Like losing radio code, ECU reset, window settings, rear wheels falling off...?
Offline Baz300
Re: Disconnecting the battery - problems?
« Reply #1 on: February 03, 2013, 11:14:43 am »
Shouldn't have any problems I have disconnected my battery plenty of times and the stereo has never needed the code to be enterd.
Just have your keys handy as the alarm will sound when you dissconect the positive side
« Reply #2 on: February 03, 2013, 11:21:56 am »
when you restart your car after connecting  the battery you will have a yellow and red light on the dash .go for a short drive and they should go out
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #3 on: February 03, 2013, 11:24:19 am »
You may have to re-do your windows as well, make them go all the way down then all the way back up.
Offline OSB
  • -Given: 32
« Reply #4 on: February 03, 2013, 11:52:23 am »
Thanks all. As all I want to do at present is to make sure the battery terminals are clean and earth lead is making making good contact. I'll connect a second battery through the power outlet.
Offline Scrubadub
  • Soon to be "bagged"
« Reply #5 on: February 05, 2013, 09:28:01 am »
if you have revo remap, you will lose the settings
Fun bags
Offline OSB
  • -Given: 32
« Reply #6 on: February 05, 2013, 10:33:04 am »
Thanks - bog standard (at the moment.......)
Offline chrisvectra
  • VXR IS FOR LIFE, NOT JUST FOR THRILLS
« Reply #7 on: May 16, 2015, 06:40:37 am »
Why is that?
