Author Topic: Wiring for cruise control?  (Read 6146 times)
Offline MightyMullet
  • Penzance, Cornwall
« on: February 11, 2013, 03:50:19 pm »
I know theres threads about this but i couldnt find the answer i wanted so be patient  :innocent:
I went to the stealers today to ask about retrofitting this, they said £127 fitted which i was keen for, however he said if the wiring isnt there itll be nearer £300 :surprised:
So basically, is there anyway of telling if the wiring is there without tearing everything apart?
If not, what do i take off and what do i look for?
Cheers guys :drinking:
Offline S2 Ant
  • -Receive: 21
Re: Wiring for cruise control?
« Reply #1 on: February 11, 2013, 03:51:40 pm »
I think EddieNL is the guy to be asking about this on here - he seems to have very good feedback on helping people with things just like this I believe
Ant
« Reply #2 on: February 11, 2013, 03:57:28 pm »
its after a certain year they put the wire there..know on mine 54plate the extra wire had to be put in but charging £300 :stupid:
« Reply #3 on: February 11, 2013, 04:00:20 pm »
Cheers mate, ill drop him a pm if he dont see this :), the only reason im doing it at VW is it still has 10 month warranty. But i wont pay £300.
I know crazy for a wire, mines feb 2006 on a 55 plate!
« Reply #4 on: February 11, 2013, 04:04:49 pm »
think yours will need the wire..
« Reply #5 on: February 11, 2013, 04:14:24 pm »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: February 11, 2013, 04:24:20 pm »
you could be lucky if your car is a MY2006
where are you located?
Cluster and Key coding
Location Great Yarmouth
« Reply #7 on: February 11, 2013, 04:25:13 pm »
its not as bad as you think..When Ed did mine i had already removed the wipes arms and scuttle panel..then feed a piece of wire from inside the car to the ecu ; Think it took an hour to do the job lot
« Reply #8 on: February 11, 2013, 04:34:36 pm »
Penzance, Cornwall. Miles from anywhere. Is there anyway of finding out?
Certainly good to here thanks  :drinking:
Offline Baz300
« Reply #9 on: February 11, 2013, 05:17:58 pm »
My car is a 2006 (55 plate)and the wire was already in place
« Reply #10 on: February 11, 2013, 05:27:58 pm »
Great news  :drinking:
Is the build date stamped anywhere? If its after june 2005 the its my2006 yes?
« Reply #11 on: February 11, 2013, 05:32:49 pm »
.should tell you on your v5 form what year it is-mine is registered 2005 but on a 54plate
« Last Edit: February 11, 2013, 05:35:01 pm by maxitrol »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: February 11, 2013, 06:41:06 pm »
You can tell by your vin number
2006MY = WVWZZZ1KZ6W??????
2005MY = WVWZZZ1KZ5W??????
homesqueeze
« Reply #13 on: February 11, 2013, 07:02:53 pm »
Got my car in '05 with an '05 plate. Don't know if it had a wire or not, but VW charged me £167 all in to retro fit cruise last year.
Offline A1dan2.0tdisport
« Reply #14 on: February 11, 2013, 07:11:23 pm »
Iv just bought a cruise stalk off vee-dubber, if the wire is already there in my car, do I just need to plug and play and then have someone activate in vcds?
