Author Topic: Dash rattle driving me crazy!!  (Read 2175 times)
Offline rf860
« on: February 21, 2013, 09:07:08 pm »
I've got a rattle/buzzing coming from the dash top mounted vent in my car pretty much constantly when driving. It's driving me insane! I've taken the top 'mesh' plastic section out and packed around the edges with sound deadening material but it still rattles. I'm thinking it's the flat plastic bit below the mesh section that is causing is but i'm not sure how to remove it? I can see one torx style screw, but does it then pull out? Need to sort this ASAP!!
Offline ell.s
Re: Dash rattle driving me crazy!!
« Reply #1 on: February 21, 2013, 09:10:17 pm »
I've got the same issue  :sad1:
Offline doylebros
  • -Receive: 310
« Reply #2 on: February 21, 2013, 09:12:28 pm »
Read this and watch the video link it should help you
http://www.mk5golfgti.co.uk/forum/index.php/topic,53205.0.html
Offline rf860
« Reply #3 on: February 21, 2013, 09:27:32 pm »
Thanks for that! That's my job for this weekend sorted :)
Offline doylebros
  • -Receive: 310
« Reply #4 on: February 21, 2013, 09:29:50 pm »
Happy to help  :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: February 21, 2013, 10:09:59 pm »
Have a rattle in there too.  :sick: annoying little thing that.
Also have one coming from the back, it's as if the back door boot is not shuting right????
annoying thing that too., I have to turn the music up to block it out,  :signLOL:
Silver is the way !
Offline doylebros
  • -Receive: 310
« Reply #6 on: February 21, 2013, 10:16:44 pm »
More common the rear seats have not been fitted back into the catch correctly - open them and reset them back into the catch - try that first quick repair!
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: February 21, 2013, 10:25:39 pm »
Yes mate tried that, had someone sitting in the back trying all sorts for me lol... but the only thing we assume to be left is the door???????
it is like a clinking sound, i thought it was my seats as thats what it sounded like, but have them rulled out...
Silver is the way !
Offline doylebros
  • -Receive: 310
« Reply #8 on: February 21, 2013, 10:31:56 pm »
Open the door slightly when driving (using a third party) and see if that cures it first - easiest first (worn latch).
If that doesn't cure it then take the door card off.
Offline gigolo456
« Reply #9 on: February 21, 2013, 10:33:52 pm »
Ref the rattle coming from the back, have you got an aftermarket exhaust fitted by any chance??
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #10 on: February 21, 2013, 10:47:38 pm »
Funny Thats what it sounds like the door latch... Would that mean a new latch or maybe just adjust it ?
Yes i have a mille on, but it deffo seems to be on the inside. the exhaust has to come of here pretty soon, so i will be checking it, what you thinking maybe a worn rubber mount???
thanks guys for the help and heads up on this... as we all know rattles do our heads in. and i would be one to try and have everything perfect well as perfect as can be....  :happy2:
Silver is the way !
Offline gigolo456
« Reply #11 on: February 21, 2013, 11:03:58 pm »
well i have a BCS, although my rattle only arose when engine was warn, and yes, it did sound like the boot wasnt closed properly! Had the exhaust adjusted, just down from where it meets the turbo, i think they actually lengthened it by all accts, only about a half inch, and heh presto, rattle stopped (touching wood!!)!!
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #12 on: February 21, 2013, 11:14:39 pm »
Thanks for that Gigolo, I will look into that tomorrow, and report back...
Silver is the way !
Offline MrDo
« Reply #13 on: February 23, 2013, 01:49:57 pm »
Check your boot latch in the tail gate is not loose. You can grab it and waggle it to find out.
Mine had come loose just aftet I bought the car and rattled over speed bumps. Easy to fix just tighten bolts under plastic boot cover either side of the latch.
