Author Topic: Just exactly how much power can you get from a 2.0TFSI K04?  (Read 14077 times)
« on: February 26, 2013, 08:01:19 pm »
How far can you go?
Engine power mods only.......
CDL block
K04 turbo
90mm downpipe, then 3" straight through decat exhaust.
Loba? HPFP
CAI? Type? Air feed location?
Water methanol injection...make? Single or direct port?
Throttle pipe
Intercooler...type?
Hosing...which ones
Catch can or just BSH PCV fix?
DV...stock or aftermarket?
Boost controller or ECU control?
Porting?
LPFP upgrade?
Okada's ...worth it or not?
Competition gasket and head studs needed?
Runner flap delete on intake manifold?
Spark plugs..OEM or NGK's?
Sump, baffled or not needed?
Internals needed? Pistons and rods or just rods?
Any more?
« Last Edit: February 26, 2013, 09:52:16 pm by Hurdy »
Re: Just exactly how much power can you get from a 2.0TFSI K04?
« Reply #1 on: February 26, 2013, 08:02:55 pm »
you already know the answer John  :signLOL: meth and NOS job done  :signLOL: :driver:
« Reply #2 on: February 26, 2013, 08:06:57 pm »
LOL - forget NOS. Although I guess that would be the limit! :rolleye:
I'm talking bolt-ons and air flow etc and yes WMI!
« Reply #3 on: February 26, 2013, 08:13:47 pm »
depends on the dyno then  :signLOL:
Offline Shorty
  • -Receive: 25
« Reply #4 on: February 26, 2013, 08:30:58 pm »
I'd say just over 400 with WMI and as much boost as you can get?
| Mk7 R |
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #5 on: February 26, 2013, 08:33:59 pm »
Nick @ R-Tech managed 404bhp and something like 460lb ft from K04 & WMI before he hit the limits of the LPFP on James's. then de-tuned to the 378bhp / 450lbft to keep it sweet until he could get the fuel in
I'm guessing NOS would give even more. . .
« Reply #6 on: February 26, 2013, 09:40:37 pm »
Yes NOS gave me 438bhp and 510lbft on my old ED30!
Unfortunately it costs around £1 a second to run and empties two tanks in 100 seconds!
Okay, I'll put some mods up in the first post and let's build a virtual mk5golfgti.co.uk K04 Monster :jumpmove:
NOT using NOS! :laugh:
« Reply #7 on: February 26, 2013, 09:45:20 pm »
I guess it depends on whether you want to do valve train and bottom end to make it rev.
« Reply #8 on: February 26, 2013, 09:54:17 pm »
Is there anything in the K04 after 7k rpm's though Ian? From everything I've seen the K04 is done by then, in fact before!
« Reply #9 on: February 26, 2013, 10:04:23 pm »
Fair enough John. If the K04 can't shift the air then scrap that.
Offline dokez
« Reply #10 on: February 26, 2013, 11:52:29 pm »
you got a progres thread on your yed30 please?
Offline james
« Reply #11 on: February 27, 2013, 12:21:54 am »
Nology silver tip plugs gapped to 0.75,   Stopped me burning plugs when reving to 7k  :drinking:
« Reply #12 on: February 27, 2013, 12:29:10 am »
How far can you go?
CDL block
K04 turbo
90mm downpipe, then 3" straight through decat exhaust. 90mm straight through
Loba? HPFP
Throttle pipe
Intercooler...type? THS
Hosing...which ones SFS should do it
DV...stock or aftermarket? Forge Oversized?
Porting?
LPFP upgrade?
Sump, baffled or not needed? Not needed unless tracking
Camshafts?
102RON fuel
Any more?
Offline james
« Reply #13 on: February 27, 2013, 05:41:43 am »
My input...
CDL block  (best block)
K04 turbo ( adjust actuator, makes you hold boost longer ( you could set it to 30psi top end but it would not make it as it blows the westgate open))
90mm downpipe, then 3" (best you can get)
Loba? HPFP ( APR people say, but i run the cheap option and has not failed me)[/
CAI? Type? Air feed location?  ( I have tested a evom intake + having no intake and it makes the same power)
Water methanol injection...  ( stage 3 snow kit running duel, with tb spacer.  Gives a better spray)
Throttle pipe ( BSH )
Intercooler...type? THS < same + remove ac rad
Hosing... - NEUSpeed pipes
Catch can or just BSH PCV fix?  ( i run a catch can just to catch excess meth)
DV...stock or aftermarket? Forge Oversized? (Stock Dv works fine no need  for anything else)
Boost controller or ECU control? ( ECU also does the job fine get far more control)
Porting? ( someone done this and made an extra 10bhp)
LPFP upgrade? ( 100% needed over 390bhp unless you decresse the torque)   (RS3/ttrs pump works well)
competition gasket and head studs needed? (not needed for k04)
Runner flap delete on intake manifold? ( No point for k04 - only for big turbo)
Spark plugs..OEM or NGK's? (Nology silver)
Internals needed? Pistons and rods or just rods? ( CDL take everything the k04 can give)
Camshafts - (might get a extra power top end)
I think the max you will get is around 390-430
« Last Edit: February 27, 2013, 07:00:35 am by james »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #14 on: February 27, 2013, 06:57:26 am »
As much as i like the K04 it has 2 weaknesses:
1. It trails off in the 5000+ range
2. It has with most tunes a torgue peak that destroys a normally nice curve.
That being said James is right in his assesment, "he of all should know  :signLOL: "
However a DD of a well setup LO380 would be great to see  :happy2:
Over the top mod list ;o)
