Author Topic: Help please!  (Read 1754 times)
ReeceH13
Help please!
« on: March 03, 2013, 03:38:57 pm »
Hey guys,
Just had this lovely light come on... Anyone know what it could mean, worst/best scenario?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Help please!
« Reply #1 on: March 03, 2013, 03:42:33 pm »
Catalyst fault.
'07 Red manual
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Help please!
« Reply #2 on: March 03, 2013, 03:44:19 pm »
Is it flashing or solid?
Does seem to be emissions related...
http://www.vwgenuineparts.co.uk/vw_maintenance_yellow_warning.shtml
Offline Gazza747
Re: Help please!
« Reply #3 on: March 03, 2013, 04:24:50 pm »
I have the same light on at the moment on my car. It's the exhaust system warning light and could be on of lots of differnet faults.
You need to find out what errors have been recorded.
I have a warranty and when VW read the errors, they had to send the infomation off to VW as they didn't have a set fix for the issue. VW than came back and it needs to go on tommorow for an oil pressure test and then go from there. They did mention timing chain tensioner as one possiblilty.
I have had the light go on for a bit and off for a bit for a while now, no issue with performance or driving the car.
edit:
I just went and topped up the oil, started the car and the light has gone out. Maybe the light comes on as the oil runs low? Still I'm getting a free courtesy car so may as well let VW sort it out.
« Last Edit: March 03, 2013, 04:47:31 pm by Gazza747 »
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
ReeceH13
Re: Help please!
« Reply #4 on: March 03, 2013, 04:35:20 pm »
Thanks for your help as always. It has gone now for whatever reason... I'll monitor it but don't know if I should get it looked at anyway what do you think?
Offline Little_Dave
Re: Help please!
« Reply #5 on: March 03, 2013, 04:41:33 pm »
What was you doing when it came on?
Had this quite a while ago, the car would stutter and misfire when accelerating followed by that flashing then going out
Turned out to be a coil pack in the end but could also be worth checking the spark plugs too :happy2:
HTH
Dave
ReeceH13
Re: Help please!
« Reply #6 on: March 03, 2013, 04:45:34 pm »
Thanks Dave. Was driving for an hour and a half, stopped into Starbucks with the Misses, come back out and it come on when I put the ignition on. Had the coil pack changed at VW along with the Spark plugs not too long ago so I'm mythed, could it be oil pressure, or the cat? I wonder if the AA will scan it for me...
Offline Gazza747
Re: Help please!
« Reply #7 on: March 03, 2013, 04:49:22 pm »
I've just added to my post above as it's gone out again!
Re: Help please!
« Reply #8 on: March 03, 2013, 04:53:29 pm »
Get it scanned... it could be a hundred things.
It wont be oil pressure though.
Offline chowgar
Re: Help please!
« Reply #9 on: March 03, 2013, 05:26:49 pm »
They'll switch on and off as they will be on key turn cycles...
ReeceH13
Re: Help please!
« Reply #10 on: March 03, 2013, 06:38:48 pm »
Ah right I see. So the problem may still be there it's a matter or when it comes back on?
Offline TANNER
Re: Help please!
« Reply #11 on: March 03, 2013, 07:20:45 pm »
Ive had this on a previous car which turned out to be a shot lead. Another thing to check.
