Author Topic: Mayo on oil fillter a little on the dip stick  (Read 4621 times)
Offline petemcr
« on: March 20, 2013, 02:17:46 pm »
Only just got my GTI and it's pretty high miles so I'm a little paranoid with it as it's my daily
I noticed a some mayo on the oil filler and also appears to have a little on the dipstick, my imediate reaction has been the headgasket has gone but I've done a little searching on here/google and some people are saying this is normal, esp over winter
I cleared it off and came to work which is about 18miles and it hasn't come back and it doesn't seem to be using any coolant, only had the car for a week though but I'm keeping an eye on it
in everyones experience is this something I should be worrying about? or is it condensation which seems to pop up quite often given that winter doesn't seem to want to go this year
thanks in advance
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Mayo on oil fillter a little on the dip stick
« Reply #1 on: March 20, 2013, 02:47:39 pm »
Don't worry about it. Burn it off with your right foot.
'07 Red manual
Offline petemcr
« Reply #2 on: March 20, 2013, 02:50:15 pm »
ahahaha
that shouldn't be an issue
when I checked it I had only drove a bit down the road, that's when it was heavy, but I've just come to work and it's not as bad now but still noticed a little on the dip stick, still not used any water though
thanks for the excuse to put my foot down a bit :D
homesqueeze
« Reply #3 on: March 20, 2013, 06:20:18 pm »
Perfectly normal if you are doing short distances. Especially in winter like you say.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #4 on: March 21, 2013, 07:34:56 pm »
Italian tune up once a week should do the trick :)
Offline sandancer
« Reply #5 on: March 24, 2013, 09:01:07 pm »
Mines been like it for the last few months, a 200 miles blast to the Lakes and back didn't even shift it !
Offline sanj
  • -Given: 17
« Reply #6 on: March 24, 2013, 09:53:37 pm »
Got a shock when I took mine off as the weather has been bad for a month's now and it looked like soft ice cream,hope it warm's up soon! :surprised:
Offline valle
« Reply #7 on: March 25, 2013, 10:04:15 am »
Mine has the same problem. Winter and short drives...also can be seen on oil cap, if i remove it. I have also noticed that in winter time, when i don't drive much my oil catch can is filed up very quick...
Offline petemcr
« Reply #8 on: March 25, 2013, 07:15:00 pm »
I've noticed now after taking it for a long spirited drive majority of it has gone which is good, would be nice if the weather hurry and warm up as well
Offline Spadds
« Reply #9 on: March 29, 2013, 07:55:31 am »
I found this on our old mk3 gti 8v coupled with a water leak on the cylinder head and I immediately diagnosed as fail head gasket.
However a mate pointed out it could just be condensate as the mrs does loads of short drives.
I changed the oil, checked the coolant levels and cleaned the filler cap and took it for a spin.  All is well!  Still, this did inspire me to sell it and get the mk5 as we wanted a newer 5 door for the bambino!
So, all was well in the end!  :-)
Offline OSB
  • -Given: 32
« Reply #10 on: March 29, 2013, 04:07:21 pm »
Yep got the mayo on mine too!
The last car I had which suffered from this was a Mk1 Cortina GT. So that dates it a bit...
The cause then, and on various cars, was using Castrol oil - which was prone to mayo - as against Duckhams - which wasn't.
Not sure that info is much help now though  :laugh:
Or is it? Is there any correlation between different brands of oil and the amount of mayo?
Just a thought ........
Offline Bow
« Reply #11 on: March 29, 2013, 04:42:48 pm »
Mine had it took my mechanic who straight away said not to worry only from short distant journeys etc did head gasket test on coolant and compression rest on cylinders to prove and put mind at rest car was perfect so do not worry so much
Offline Jme
« Reply #12 on: March 29, 2013, 05:11:22 pm »
Hi mate yeah I have the same on my gti (60k on clock) and also the other half's 2006 beetle. The beetle has been like that for last 4 years with no probs. Seems to be a characteristic of the vw's as my dads bora the same lol
Mk5 GTI manual 3Door.
Mods to date. De-badged, led/smd inside and out.
Mods to do.    Led/smd puddle lights, satnav, Bluetooth,
                     Induction kit, exhaust, hid/led fog drls, +++
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #13 on: April 01, 2013, 03:15:25 pm »
Mine does the same, has been doing it for the last 3 years. No worries
Offline OSB
  • -Given: 32
« Reply #14 on: April 01, 2013, 04:10:53 pm »
So I have been keeping an eye on mine and a friends GTI recently - we both changed from Castrol to Motul oil a couple of months ago. Same type of driving and mileage.
Much less mayo with the Motul ...
Anyone else noticed a difference?
