Author Topic: Wing mirror indicator  (Read 14293 times)
Offline paulw123
  • -Receive: 47
Re: Wing mirror indicator
« Reply #15 on: April 18, 2013, 12:09:36 pm »
my faulty lh had got water in it and gone all mouldy  :sick:
when i replaced the rh, the casting fractured aroung the tapped hole due to corrosion around the screw  :scared:
Offline Ranbeer Singh
« Reply #16 on: April 18, 2013, 12:13:42 pm »
Thanks for the info.... these do seem to be a problem and maybe a bit too tricky for me to fix... Rang my local rip off dealer and they have quoted about £90 to replace one! Anyone know where I can get these sorted cheaper?
Rick
Coventry
Offline Kalpsn2000
  • -Receive: 56
« Reply #17 on: April 18, 2013, 01:16:13 pm »
Do it yourself. Just follow the guide Martin (MC71) linked on pg1. I followed that guide when changing mine :happy2:
Offline GTI-Pirelli
  • -Receive: 27
« Reply #18 on: April 18, 2013, 03:40:42 pm »
Just called Listers Nuneaton for part price:
Left:   1K0 949 101
Right: 1K0 949 102
Both are £24.49ea inc VAT.
Fit it yourself! It isn't a difficult thing to do (as others here have stated).
2017 Audi S4
Offline paulw123
  • -Receive: 47
« Reply #19 on: April 18, 2013, 04:09:55 pm »
I bought a 300mm long T8 torx screw driver off ebay, then its easy to do with everything in situ, just have to prise the cover off gently, tilt the glass out so there is enough access to the 2 screws that need removing, unplug power socket and replace with new unit. Take it slowly, worth a go, if you get stuck, then take to £90 a side dealer.
Offline ConeKiller
« Reply #20 on: April 18, 2013, 04:59:18 pm »
I literally did this yesterday on the girlfriends EOS, same mirrors!
Easy to do, took me 20 mins max!
That guide is exactly what I did but you dont need to unplug the mirror or motor!
