Author Topic: The ECON button - What a confusing little thing  (Read 99292 times)
Offline alexmccabe
    • Alex McCabe
Re: The ECON button - What a confusing little thing
« Reply #30 on: June 05, 2013, 12:48:16 pm »
I'm going to confuse things a little more.
The GTI (UK model) has automatic climate control.  It's designed to work like this:
If you press 'auto' and set the desired temperature, the smurf inside your dashboard will switch on the air-con system if it thinks it needs it and directs the airflow around the cabin as it sees fit.  There are sensors in the cabin to monitor interior temperature.  If the temperature and humidity dictate, then air-con smurf may decide not to bring in the air-con (although, as far as I can tell, this is rare).  It will turn fan speed up and down to heat or cool the cabin temperature as quickly as possible.
Econ is one of the ways to override the automatic climate control and as others have already said, it stops the air-con compressor from kicking in.  Everything else will still work, but you may never chill the car to the desired temperature on a hot day by using ambient air.  Windscreen de-mist and the directional buttons are other over-rides.  You can speed up the chilling of a car by using the recirculating button, which works by sending the air you've already chilled back round again and again.  Don't leave this feature on for too long - the lack of fresh air may make you drowsy.  A bit like reading to the bottom of this reply, I guess.
:grin:
I think you are bang on m8... Although I think it will only stay in recirc for a set time...
Is it possible that the control panel has been changed to the later type but someone has fitted the older type knob that has Econ on it instead of AC ...
I think a little experimentation is in order (just to clarify, with the control unit...  :wink: ). I thought if you swap out the panel for an A/C one you had to swap some other stuff too...? I dunno.
I will see if I can get it to blow truly cold air on the way home this evening, if not I will have to go for an AirCon service  :fighting: Expensive!
MK5 Golf GTi 197BHP Tornado Red
Offline ARV_90
« Reply #31 on: June 05, 2013, 06:31:18 pm »
:grin:
Just a thought... as it seems to be working like it should have the AC button.
Offline manc01
« Reply #32 on: June 05, 2013, 07:12:48 pm »
I have ECON button, its 56 plate. When its lit up the AC is not working, when the light is off then AC working. This was also confirmed by VW tech, for whats it worth, as I had to get my compressor changed, luckily under warranty.. :smiley:
Offline Scrubadub
  • Soon to be "bagged"
« Reply #33 on: June 05, 2013, 07:42:31 pm »
wish id of pressed "econ" when having car dyno'd, might of got another horse or 2   :evilgrin:
Fun bags
Offline alexmccabe
    • Alex McCabe
« Reply #34 on: June 06, 2013, 06:10:03 pm »
Would it be possible for it to blow warmer air on the aircon setting if the gas was out or the pump was broken? I ask because the difference between econ and non-econ is very minimal, with the econ mode on being a couple degrees cooler.
Offline matmk5
    • Derpage - Urban Exploration Photography
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,112764.0.html
« Reply #35 on: June 06, 2013, 06:28:40 pm »
I cant believe I have gone nearly two months without figuring out the Econ button is the Aircon button lol
My Urban exploration photography website www.derpage.com
Offline Gazza747
« Reply #36 on: June 08, 2013, 08:56:52 pm »
:grin:
I would suggest getting an aircon service as if you run without gas you may damage the compressor and that would end up being much more expensive
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline Scrubadub
« Reply #37 on: June 08, 2013, 09:47:03 pm »
Matt, econ ISN'T the air con on
Fun bags
Offline dmac1969
  • -Receive: 21
« Reply #38 on: June 10, 2013, 09:51:42 pm »
Econ lit - aircon off
Econ unlit - aircon ON.
Ive had both versions (and 05 and now a 58) and I dont understand why they didnt do it the AC way from the start!
Offline NotKolio
  • Newbie
Re: ECON CLIMATIC PANEL, CAN IT BE SWAPPED WITH A AC BUTTON ONE
« Reply #39 on: June 11, 2026, 03:09:53 pm »
I bought a golf mk6 GTD interior rear ann front seats with heating, my golf mk5 didnt have heated seats so i need to change my climatic panel to the same one with seat heating button, but i cannot find a ECON one, and from what i read online if i put a AC one i till screw up my logic and the ac and the air recirculation wont work properly or at all, and cannot be codded with VCDS. Has anyone done this swap and what did you do to make it work properly or did it even work at all.
Offline ZoliWorks
« Reply #40 on: July 02, 2026, 12:46:57 am »
If your car is pre 2007, get an ECON one. If it's post 2007, get an AC one. Breaker parts sites such as Euroimpex or Ovoko which deliver all over the world have them.
https://shop.euroimpex.lt/en/search?categories=343&vehicles=2,173,2496
« Last Edit: July 02, 2026, 12:48:56 am by ZoliWorks »
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
