September 22, 2026, 07:45:20 pm
All Things Mk5
Mk5 General Area
Mk5 golf gti actuator
Topic: Mk5 golf gti actuator (Read 2297 times)
adgti
Always Involved
-Given: 0
-Receive: 4
June 04, 2013, 07:04:08 pm »
Is there an uprated actuator for the k03?
bacillus
Just look at my post count
-Given: 4
-Receive: 453
Re: Mk5 golf gti actuator
Reply #1 on:
June 04, 2013, 07:25:24 pm »
Forge does one.
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=&product=FMACVAG05
adgti
Always Involved
-Given: 0
-Receive: 4
Reply #2 on:
June 04, 2013, 07:42:53 pm »
ahhh but aren't they electric as standard? where would I get the vacuum from?
adgti
Always Involved
-Given: 0
-Receive: 4
Reply #3 on:
June 04, 2013, 08:26:11 pm »
any one?
adgti
Always Involved
-Given: 0
-Receive: 4
Reply #4 on:
June 05, 2013, 12:56:15 am »
Need to order one if it will work? Will I get a CEL?
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #5 on:
June 05, 2013, 01:01:40 am »
Im pretty sure theres no point in doing this.
https://www.justgiving.com/thenational3peaks
adgti
Always Involved
-Given: 0
-Receive: 4
Reply #6 on:
June 05, 2013, 09:49:30 pm »
Even if my standard one is f*cked?
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #7 on:
June 05, 2013, 09:57:05 pm »
Just replace with OEM.
bacillus
-Given: 4
-Receive: 453
Reply #8 on:
June 05, 2013, 10:12:38 pm »
If you get the forge actuator with a
green
spring it will be almost exactly the same spec as an oem one.
The forge one should crack at 5psi vs the oem one at 4psi.
rubber toe
Always Involved
-Given: 21
-Receive: 8
Reply #9 on:
June 05, 2013, 10:57:46 pm »
Quote from: adgti on June 05, 2013, 09:49:30 pm
What symptoms/faults you getting with the car ? Is the actuator not holding vacuum ?
All Things Mk5
Mk5 General Area
