September 02, 2026, 02:00:32 am
All Things Mk5
How to Guides / Troubleshooting
Downshifting with paddle shift
Topic: Downshifting with paddle shift (Read 5303 times)
Marc-5-GTI
Won't Shut up.
-Given: 13
-Receive: 26
June 05, 2013, 03:39:00 pm »
Does anyone else's downshifts with the DSG Box quite harsh? Mines quite harsh on the way down but in an R32 I test drove it was seamless.... Uh oh?
Hurdy
Just look at my post count
-Given: 52
-Receive: 137
Re: Downshifting with paddle shift
Reply #1 on:
June 05, 2013, 04:55:21 pm »
Silky smooth on my R, but the DSG box is mapped. As stock it wasn't clunky, just slower.
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #2 on:
June 05, 2013, 04:58:14 pm »
Try a DSG adaption.
Mine is pretty smooth. Not as smooth as the upshifts, but a lot of it depends on what you are doing.
If you are decellerating and change down it's really good. If you are accelerating and then change down it can confuse it.
6th to 5th is always really good though.
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
Marc-5-GTI
Won't Shut up.
-Given: 13
-Receive: 26
Reply #3 on:
June 05, 2013, 05:13:45 pm »
It's just under braking going 3-2-1, it's fine in D and S just harsh in manual
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #4 on:
June 05, 2013, 05:15:13 pm »
Mines not that smooth 2-1. When braking to a stop I let it just do its thing. I never manually shift 2-1. There's no need.
https://www.justgiving.com/thenational3peaks
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #5 on:
June 05, 2013, 05:18:12 pm »
I agree about 2-1 being crap.
Very rarely does it ever go to 1 in D, unless I literally stop. Thank god.
Detailing Guide
Wheel Fitment Guide
SRC
Always Involved
-Given: 21
-Receive: 27
Reply #6 on:
June 05, 2013, 09:01:55 pm »
On a local steep hill, I need second gear to hold the speed down. I've found that a tiny bit of pressure on the throttle - not enough to cause acceleration - smoothes the down-change from third noticeably. Not sure why, as the engine still revs to match the gear, but it definitely helps.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods: Seat inserts and a VW bottle opener. Each worth 20bhp.
Dave J
Won't Shut up.
-Given: 45
-Receive: 63
My Ride:
Reply #7 on:
June 05, 2013, 10:10:47 pm »
Coasting under engine braking, mine's fine - perfectly smooth, and same under braking.
As said before, 2-1 is a bit clunky, so I don't bother with that change when in manual mode.
Much age difference between the R and yours?
Edition 30 - no. 1387
Marc-5-GTI
Won't Shut up.
-Given: 13
-Receive: 26
Reply #8 on:
June 05, 2013, 10:28:16 pm »
It's just over a year younger then my gti, with 10k less miles... If its similar with a lot of people it gives me peace of mind. Apart from that the 'box is brilliant.
Thanks for the replies.
Jussa
-Given: 23
-Receive: 12
Bicester
Reply #9 on:
June 05, 2013, 10:55:44 pm »
Mines only a bit clunky if I gear down while braking heavily - in other words gears are changing at the wrong revs if u get my drift??
Hurdy
-Given: 52
-Receive: 137
Reply #10 on:
June 06, 2013, 08:28:33 am »
Ahh 2nd to 1st in manual mode. I know never use that combination as 1st is only an acceleration gear and not for deceleration, but if it is used it isnt smooth. Drive mode never goes into 1st unless you come to a standstill. Around town I use drive mode when setting off and stopping and then flip into manual mode once away, unless I'm doing a fast getaway at the lights.
RENNTAG
Won't Shut up.
-Given: 15
-Receive: 23
Premium Performance Parts
Reply #11 on:
June 06, 2013, 08:55:28 am »
Yes shifting down the lower gears is a bit clunky on mine.
To make down shifts in manual mode quicker when you are changing down to accelerate, i have found applying some throttle before changing down makes it much quicker. The gearbox must know if you are accelerating that you will want to change down a gear or two.
Scottymon
-Given: 83
-Receive: 125
UnNaturally Aspirated
My Ride:
Reply #12 on:
June 06, 2013, 10:02:07 am »
^ sounds good practice to rev match
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #13 on:
June 06, 2013, 10:09:57 am »
Quote from: Scottymon on June 06, 2013, 10:02:07 am
And how does that work on a DSG....
Scottymon
-Given: 83
-Receive: 125
My Ride:
Reply #14 on:
June 06, 2013, 10:27:31 am »
Just before downshifting press the accelerator a bit further (similar firmness to when you are overtaking). The box will then pre-select the next lower gear, and when you click the down paddle you will get a smooth, no hesitation down gear change. The best rev match you will achieve on a granny box.
All Things Mk5
