Author Topic: Make the GTI drink less?  (Read 7756 times)
Offline RedED30
  • -Given: 19
Re: Make the GTI drink less?
« Reply #15 on: June 15, 2013, 07:33:13 am »
Is there any chance you could cycle for some of your town trips? Only way I can think of to reduce your petrol costs with the gti around own.
This is what i do, plus it keeps miles down.
I can get 32/33mpg if i use MY revo tweaked map (using sps turing boost and fuel right down) and leave her in D (DSG), no aircon, windows closed, carrying nothing in car bar me.
Revo Stage2 - With Linear Throttle
Revo DSG
BCS Turboback Powervalve - This is a must.
ITG Closed Intake.. wooosh
Here to enjoy and help, with a hint of sarcasm, please do not be offended
Offline jamma
« Reply #16 on: June 15, 2013, 08:32:08 am »
I average 31 mpg driving from London to Bournemouth each weekend although I do bomb it. I set cruise at 50 on m11 on Thursday as I had plenty of time just to see what I could get , it was 44,3 mpg and I have revo stage 1 map . Pretty impressed with that
Offline marcnazer
« Reply #17 on: June 15, 2013, 10:05:26 am »
That is impressive!
Im in Bournemouth too.
Unfortunately I need to use the car for work for ferrying clients around all day so the bike isnt an option.
I might give Revo a ring and see what they think I could get out of it with one of their maps...although they are bound to be a little optimistic
Offline marcnazer
« Reply #18 on: June 15, 2013, 10:22:28 am »
oh and also what psi is full load level?
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #19 on: June 15, 2013, 11:37:39 am »
Push it..?
Seriously though that's the best you are going to get around town tbh, even if you bought a diesel it'll still be relatively crap on juice on town driving (My old A3 2.0Tdi 140) would do 35mpg at best round town..
We won't help Steve I'm sure by saying I get more in the Audi nipping across town roughly 3 miles (34-37mpg) than I did the best combined figure ever in the GTI (35mpg), will we?
 :evilgrin: :innocent:
The raw facts are though that the majority of owners haven't seen above 38-40mpg even on long journeys, around town 24mpg is a rough marker and the rest is somewhere inbetween. It's not a car or engine you can squeeze economy out of like you would a more recent diesel or TSI block.
Keep it well maintained and enjoy it for what it does  :smiley:
Pete
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #20 on: June 15, 2013, 12:13:23 pm »
To get the most out of the TFSI, use light throttle and try to keep it "off boost". 40+mpg is possible on a long steady motorway run (even with cruise control). Coasting up to junctions uses no fuel in modern cars so take your foot off the gas well in advance of junctions and traffic lights and keep off the brakes as a result.  :happy2:
Tyre pressures, good fuel and a well serviced engine help, as does a good thrashing to the redline every now and again
Offline numec
« Reply #21 on: June 15, 2013, 02:18:46 pm »
From my recent 1040 miles trip  :driver: :happy2:
2.5 tanks for the whole trip
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #22 on: June 15, 2013, 06:35:04 pm »
anything you do to make the car more economical will cost more unless you're keeping the car for a VERY long time.
things you can do (in no particular order)
1. warm up the engine prior to driving (tho i'm not sure if the petrol lost by having it idling would cancel out)
2. only use the air con over 40mph (mythbusters did a test which showed that this seemed to be the point where it was more economical than the added drag from a lowered window)
3. economy tyres
4. blue motion aero underbody panels
5. remap
6. use V-Power/Momentum (though from my calculations the added cost is negated by the improved fuel economy)
7. do an IAM (or similar) course. it really improves your forward vision and makes a smoother (and hence more economical) driver
8. try and plan trips so you're doing several things at once in the most efficient fashion
the 2.0T is an impressive engine. when it was new, it was very economical considering the power that was available. just as a measure, i swapped from a 2005 1.6MPI to a 2006 2.0T and saw a 10% drop in fuel economy for a 95% boost in power. on long trips the K03 engines will see up to 40mpg (the K04s are a little more than this iirc because they're off boost for longer on long trips) but around town they really aren't that good and there's just not much you can do about it!
PLANS: Stage 2+
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #23 on: June 15, 2013, 08:43:03 pm »
^^ warming up the engine before driving is the worst thing you can do for fuel consumption  :sad1: engines are thirstiest when started from cold as the ECU is dumping fuel in to heat up the cat to get it working. Best thing you can do is start up and get driving (gently), the load on the engine warms it up and gets it to is most economical fastest.
An idling engine is just pouring fuel away, and your average mpg will really suffer
Offline Beddie
  • -Receive: 76
« Reply #24 on: June 15, 2013, 08:47:54 pm »
Push it..?
Sadly that's the cold hard facts of life with a gti mate!
Even at its worst (35mpg) my A3 was still 5mpg on average better than the ed30 on a run  :surprised:
Carbon Grey Edition 35 - Here
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #25 on: June 15, 2013, 10:29:36 pm »
Push it..?
The TFSI was designed with economy in mind (direct injection etc). It's designed to run very lean on light throttle (FSI mode). It's getting the engine to go into "FSI mode" that takes careful driving. If a lot if us on here can manage it (loads of us can manage 40+mpg) then anyone can. Most people just like to boot it everywhere and say "it's a 2.0 turbo petrol" it's not about economy. . .
Power & economy (although bit at the same time), is what makes the TFSI so good  :happy2:
Offline darren4
« Reply #26 on: June 15, 2013, 11:54:32 pm »
sounds silly but have you checked your pvc and dump valve? When my partner got her edition 30 it was doing around 26mpg. Changing the ovc to the newest revision saw it rise to 32mpg which was great :)
Offline RifGTi
« Reply #27 on: June 16, 2013, 01:31:14 am »
Push it..?
How do you get it to go into FSI mode? I'm very curious to know
Offline gtipirelli
  • Golf GTi Pirelli
« Reply #28 on: June 16, 2013, 10:01:38 am »
If you are doing lots of town journeys simply switch the engine off when you are sat at the traffic lights. You will see economy jump from 25 to 30 mpg immediately
There is no other way to improve economy around town. You cannot use fuel if the engine is off. I do this automatically now at every set of lights without fail
Golf GTi Pirelli - Diamond Black, 5 Door - SOLD
now 718 Cayman S PDK
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #29 on: June 16, 2013, 10:06:30 am »
Push it..?
Light throttle, maintaining steady speed. Basically keeping it at 70mph without accelerating & decelerating. Nick @R-Tech pulled up the bit of the map that does this and explained how it works but tbh a lot of it went over my head  :grin:
