Author Topic: Heated seats stuck !  (Read 1997 times)
Offline Tr0nic
« on: June 17, 2013, 04:04:14 pm »
Well I took my GTI for a drive this sunny day, but I noticed that I was getting pretty warm despite the fact that the airco was nice and cool...
Apparantly the switch doesnt respond anymore, So it's stuck on heating 3 I estimate  :rolleye:
Any idea what to do ?  :jumping:
Milltek Catback Non Resonated - K&N panel filter with Carbonspeed, NQSBBK front, Caddy rears, CF engine cover, Bilstein B8 with Eibach Prokit, DS2500 all around
Offline danfalcon
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92069.0.html
Re: Heated seats stuck !
« Reply #1 on: June 17, 2013, 05:03:13 pm »
short term fix the seats can be unplugged from the loom underneath, not sure which of the plugs it is off the top of my head though, you will need to check up as one of them is airbag
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: June 17, 2013, 05:15:35 pm »
as a temp fix you can remove the fuse
possible issue: either a sticking relay or faulty dial on the climate panel
Cluster and Key coding
Location Great Yarmouth
Offline ali6n2
« Reply #3 on: June 17, 2013, 09:39:03 pm »
underneath its the larger plug of the 3, should be black/purple
Offline Tr0nic
« Reply #4 on: June 22, 2013, 01:52:19 pm »
I just removed the 30A fuse of them so now I'm not getting cooked :)
If it's the dial I need to replace the entire climatronic control panel ?
Offline stu_no_1
« Reply #5 on: June 25, 2013, 08:54:19 pm »
they can be picked up for about 60 quid on ebay for the whole climate control unit if thats the problem not sure how to know
