Author Topic: Cheapest place for wind back tool...  (Read 1212 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« on: June 22, 2013, 10:05:11 am »
Anyone recommend a cheap but decent wind back tool do I can sort my rear brakes? Cheers, Dom
Diesel Daily Hack.
Offline Baz300
Re: Cheapest place for wind back tool...
« Reply #1 on: June 22, 2013, 10:08:54 am »
I got one from eBay similar to this http://www.ebay.co.uk/itm/Right-Handed-BRAKE-BREAK-CALIPER-PISTON-REWIND-TOOL-VW-AUDI-GOLF-SEAT-FORD-MAZDA-/310507187975?pt=UK_Hand_Tools_Equipment&hash=item484babaf07
It done the job.
Are you changing the discs? You will need a m14 splined bit to remove the carrier
Offline paulw123
  • -Receive: 47
« Reply #2 on: June 22, 2013, 01:16:05 pm »
wow that's cheap....I had to get 1 from Halfrauds on a sunday panick jobby, about £32  :ashamed:
Offline GTI-Pirelli
  • -Receive: 27
« Reply #3 on: June 22, 2013, 01:41:05 pm »
^ Identical to mine. Just used it about 1/2 hour ago. Works well!
Make sure you get a short one. I bought one that was too long and it didn't fit in amongst the plethora of suspension parts. It was mounted in a kind of socket (I think most are) so I bashed it out, cut the end off with a grinder then put it back in. Voila, but a faf - easier than getting the bolts out though!
« Last Edit: June 22, 2013, 01:45:20 pm by GTI-Pirelli »
2017 Audi S4
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #4 on: June 22, 2013, 05:48:03 pm »
The short ones are only available as a set, to buy a M14 spline on its own will probably involve a cut and shut as described ^^^^^
Great adapting tools though! Mines just got the splines sticking out and clears the bolt by about 2mm.
Offline torque777
Re: Re: Re: Cheapest place for wind back tool...
« Reply #5 on: June 22, 2013, 07:11:18 pm »
It done the job.
I got the same ...used it yesterday on the jetta ...did a great job as mine were fully wound out :o
sent using my own fingers
« Reply #6 on: June 22, 2013, 07:18:07 pm »
http://bit.ly/Pf4QHj
Get these they are great
