Author Topic: Swapping seats...help!  (Read 1828 times)
Offline adam_may
« on: June 24, 2013, 10:17:52 am »
If i was to buy another seat from a MK5 golf would i just be able to bolt it in my MK5 golf plug it in and everything will be okay? or will it end up with airbag light ect. on? thanks adam
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Swapping seats...help!
« Reply #1 on: June 24, 2013, 02:17:34 pm »
Depends on the year of the car as the plugs are different. Airbag light may come up but i cleared mine using vcds
Offline Scaff
« Reply #2 on: June 24, 2013, 08:24:07 pm »
if the plugs are the same then make sure you remove the negative connection from the battery before you do anything and it should prevent any airbag lights coming on
Offline adam_may
« Reply #3 on: June 25, 2013, 12:10:53 pm »
okay thanks for the replys
