Author Topic: KW Clubsports v Bilstein PS9 (Pics to follow + Build Update 28/08/13)  (Read 10571 times)
Offline fuscobal
Re: KW Clubsports v Bilstein PS9 (Pics to follow + Build Update 28/08/13)
« Reply #15 on: September 22, 2013, 12:22:55 am »
I see Ohlins states their coilovers have 70n/mm (399lbs/in) springs on front and 60N/mm (342lbs/in) at the rear ! Are they linear springs ? (from the pics they look like they are) Price is around 3200-3500Euro, so even a litle less than Bilstein Clubsport (4000E) but more than KW clubsport (2500E)
PS : What were the spring rates for PSS9/10 ?
Mk5 GTI 6MT - Revo stage 3
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #16 on: September 22, 2013, 09:43:27 pm »
Yes, Road & Track are linear only.
Bilstein B16 springs are rumored as:
B16 PSS10 Golf 5:
VA: E4-FD1-Y704A00 > progressive; rate from 32.8 N/mm to 43.4 N/mm; 39 N/mm static
HA: E4-FD1-Y754A00 > progressive; rate from 33.0 N/mm to 50.1 N/mm; 50 N/mm static
R32 B16: (very) slightly stiffer.
Conclusion:
Öhlins R&T springs form a compromise between most street coilovers and clubsports. As
these are linear 60 mm dia standard, it'd be easy to replace them with the rate you want.
"You get what you pay for."
Offline fuscobal
« Reply #17 on: September 23, 2013, 05:16:59 pm »
Hmm, if so, the Ohlins is noticeably stiffer...do they also have a camber plate ? (can't see that on the pics). I really wonder if these can bring a good improvement over my B16 so I can justify spending that much on them. Also concerned about reliability on bad roads (B16 is the king of reliability from what I've seen by now among progressive coilovers)
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #18 on: September 26, 2013, 11:56:00 pm »
"Use with original top mounts"
However, they come with their own aluminium upper spring perches.
See both the product sheet and installation manual:
http://www.roadandtrackbyohlins.com/
Regarding reliability, consider Öhlins are known for making great rallye car suspensions for ages.
 :wink:
ps
I did write him an email, but still waiting for some feedback.
pps:
L.T.L. Sport
Str. Slatina nr. 1/18
Cluj Napoca 400597
Romania
Email: laszlol.tamas@gmail.com
Phone: +40 722344730
« Last Edit: September 27, 2013, 12:08:22 am by the bruce »
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #19 on: September 27, 2013, 07:00:36 pm »
Ha ha.. the town I live in...
I might pay him a visit :).
Offline fuscobal
« Reply #20 on: October 25, 2014, 11:19:39 am »
Will be ordering the R&T at the beginning of next spring. Does anyone know if :
1) Are they willing to custom valve the dampers and deliver them with stiffer springs ? (say 90-100N/mm front and 75-80N/mm rear)
2) How much more spring rate does the damper as it is allow without ruining the superb balance ? (say mabe going from 70/60 to 80/70 is still safe for these dampers without revalving or losing some pf the 20 steps of adjustement)
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #21 on: November 12, 2014, 09:31:32 pm »
Did you write to Öhlins in Sweden? If so; I'd appreciate to read their answer.
Commonly, 30 % or even more increase should not be any great deal at all.
Offline fuscobal
« Reply #22 on: November 13, 2014, 11:43:25 pm »
I did write Ohlins on facebook but they've sent me to the Romanian dealer who was very expeditive with not too many details. 30% would be more than enough but I'd like to hear their answer, not some dealer that doesn't seem to know too much or is cheap on words !
Offline fuscobal
« Reply #23 on: December 27, 2014, 06:13:27 pm »
Swift springs answered my email >
"General rule of thumb that a lot of coilover manufacturers say is 2kg up and down. Most users we work with go as far as 4kg up and down without feeling extremely oversprung.
  And in your case going 2kg up in rate will not be an issue at all. The Ohlin shocks tend to have a fairly big range in damping adjustment. The part numbers you found are correct for what you are looking for. For a track setup however especially on a GTI most people like the way the car feels with a slightly stiffer rear spring rate over the front. So I would suggest maybe a
f-8kg/R-9kg
f-9kg/R-10kg
Of course these are just suggestions, based off of what we see a lot of people running for their track setup."
