Author Topic: Rcd510 aux problem  (Read 4151 times)
Offline ukshaun
  • If in doubt.. flat out
Rcd510 aux problem
« on: July 20, 2013, 09:05:10 pm »
Hi
I have just fitted an rcd 510 dab and I have Changed the pin allocations on the quad locks that a guide says to do and my iPod dock in the glovebox does not work. If I select a song on my iPod and then plug it in it will play for about 5 seconds then cut out.
Does this need setting up with vag com or something?
My progress thread www.mk5golfgti.co.uk/forum/index.php/topic,66117.0.html
Mods done: revo map, new south boost gauge, rcd510 dab, gti grill, gti colour coded valance, tinted lights, leds, gti spoiler
Offline doylebros
  • -Receive: 310
Re: Rcd510 aux problem
« Reply #1 on: July 20, 2013, 09:17:07 pm »
This is worth a read I'm sure it will answer your problem!
http://www.mk5golfgti.co.uk/forum/index.php/topic,48882.0.html
Offline ukshaun
« Reply #2 on: July 20, 2013, 09:37:23 pm »
The guy on that thread seems to think its the hu but he isn't getting any sound and I am. Hmmmm
Offline doylebros
  • -Receive: 310
« Reply #3 on: July 20, 2013, 09:45:25 pm »
Not sure but this Link again is worth a read!
http://www.mk5golfgti.co.uk/forum/index.php/topic,32361.0.html
Offline ukshaun
« Reply #4 on: July 20, 2013, 10:07:37 pm »
I'll have a look cheer for the help  :happy2:
Offline doylebros
  • -Receive: 310
« Reply #5 on: July 20, 2013, 10:14:00 pm »
Finally it's not this issue:-
If you have plugged something into the cd changer socket of the rear of the stereo then you press 'CD' to change between the cd player on the stereo and the aux imput (either a cd changer or and mp3 aux imput)
« Last Edit: July 20, 2013, 10:16:57 pm by doylebros »
Offline ukshaun
« Reply #6 on: July 26, 2013, 09:37:58 pm »
I've tried that mate it doesn't do anything. Ill keep searching through ideas
Offline ukshaun
« Reply #7 on: August 07, 2013, 12:06:24 am »
Anymore ideas anyone please?
Offline bacillus
  • -Receive: 453
« Reply #8 on: August 07, 2013, 06:06:42 pm »
Are you sure you swapped the correct wires?
The my-gti guide suggested swaping two wires (iirc 2 &3) with my rns510 and arm rest ipod dock but in the end I only needed to move one wire.
Offline ukshaun
« Reply #9 on: August 07, 2013, 11:23:38 pm »
hmm can you remember which one you changed?
Offline bacillus
  • -Receive: 453
« Reply #10 on: August 08, 2013, 08:42:01 am »
iirc the black wire at pin 2 was moved to pin 3. On my car pin 3 was unused whereas in the guide there was a wire there.
My car originally came with a rcd500 and ipod dock in armrest.
Offline ukshaun
« Reply #11 on: August 09, 2013, 09:28:07 am »
Hmm cheers I will give this a try
Offline bacillus
  • -Receive: 453
« Reply #12 on: August 09, 2013, 09:31:50 am »
If you could post the wiring arrangement from the sticker at the top of your old head unit and your present one then it could be of assistance.
Offline ukshaun
« Reply #13 on: August 09, 2013, 01:08:37 pm »
I will try connecting it your way first and if that doesn't work then I will post a picture thanks for the help I appreciate it.
I have the car in bits now so ill let you know how I'm getting on
Offline ukshaun
« Reply #14 on: August 09, 2013, 01:14:06 pm »
Hmm turns out th a that I had already moved the black to pin 3
