Poll
IF you have an uprated clutch, do you engage the clutch pedal when starting your car?
Yes, always
11 (50%)
Never, always in neutral and clutch pedal disengaged
2 (9.1%)
Irrelevant, i have DSG
9 (40.9%)
Total Members Voted: 21
Author Topic: What procedure do you use when starting your car?  (Read 4249 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« on: July 25, 2013, 11:00:32 am »
I have just been informed that the routine involving engaging the clutch pedal when starting the car is a very very bad thing when having an uprated clutch fitted.
The golf GTI has a 180degrees axial bearing and when engaging the clutch upon startup the bearing has no lube and will therefore over time have excessive wear as a result, this again will result in a very expensive reapir in some cases to the extent that you need a new engine  :sad1:
Have this in mind guys, i will change my routine as a result of this  :sick:
« Last Edit: July 25, 2013, 01:32:24 pm by danishmkvgti »
Over the top mod list ;o)
Re: What procedure do you use when starting your car?
« Reply #1 on: July 25, 2013, 11:14:43 am »
Clutch pedal?? :stupid:
Offline graeme
« Reply #2 on: July 25, 2013, 11:19:32 am »
I have always dipped the Clutch  :scared:
anorganix
« Reply #3 on: July 25, 2013, 11:33:22 am »
Mine won't start unless I press the clutch first, so I guess they've thought about it...
Offline SyntaxTerror
« Reply #4 on: July 25, 2013, 11:52:50 am »
So the consensus here is to disengage the clutch (pedal down) when starting?
2008 Ed30 - VWR Cold-Air Intake - APR Stage 2 - Helix 'fast road' Clutch & SMF - H&R Coilovers - Pipewerx Downpipe - Whiteline Anti-Lift Kit - R888's - Dogbone insert - GFB DV+
  • -Given: 243
  • -Receive: 155
« Reply #5 on: July 25, 2013, 01:34:22 pm »
Sorry for the confusion, it's engaging the clutch pedal that is bad as you the puts the pressure from the springs on the clutch plate onto the crank as a sideways stress while there's no oil pressure on the axial bearing, not the clutch itself, my bad  :smiley:
Offline bacillus
  • -Receive: 453
« Reply #6 on: July 25, 2013, 02:14:53 pm »
I put the car in neutral, fully depress the clutch pedal then start the car.
  • -Given: 243
  • -Receive: 155
« Reply #7 on: July 25, 2013, 02:21:20 pm »
I have edited the poll due to me not being specific enough  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: July 25, 2013, 02:39:39 pm »
Axial bearing?  Thrust bearings on the crank?
Follow AKS tuning on Facebook
Offline drsilviuro
« Reply #9 on: July 25, 2013, 02:56:51 pm »
In neutral and with clutch pedal pressed I started the engine for 100.000km (50.000 with southbend stg3 daily) and no problem whatsoever!
  • -Given: 243
  • -Receive: 155
« Reply #10 on: July 25, 2013, 03:06:02 pm »
Have you had the gearbox off and measured the lateral movement after the 100.00km of use?
Offline drsilviuro
« Reply #11 on: July 25, 2013, 03:37:04 pm »
In 2 wks will take the gearbox apart for wavetrac lsd :)
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #12 on: July 25, 2013, 08:25:10 pm »
me too always thought this was correct, but jake are you saying this is only correct for a oem clutch? :confused:
Offline drsilviuro
« Reply #13 on: July 27, 2013, 08:19:00 am »
As vRSAlex said, what/where are those axial/thrust bearings? Do you have a picture of them?
Here's a diy, if you don't have pictures
 http://forums.tdiclub.com/showthread.php?t=310279
  • -Given: 243
  • -Receive: 155
« Reply #14 on: July 27, 2013, 08:53:20 am »
Yes Berg, there's a risk when having an uprated clutch and doing this procedure that you'll get sideways slack in the crank
