Author Topic: Random drive door lock issue  (Read 14129 times)
« on: August 27, 2013, 10:11:02 pm »
Hi chaps(esses)
Ive been having a problem of late where the driver door wont open with the remote central locking. I have to put the key in to unlock it.
Any ideas? New door lock unit needed?
Rich
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #1 on: August 27, 2013, 10:20:09 pm »
Does anything else on the door work? Windows? Mirror adjustment? Buttons illuminate?
Could be a broken wire leading from car to door or maybe a faulty door controller.
I fixed my brothers and it was a broken wire behind the rubber sheath between car and door.
Jas
VCDS (Preston, Lancashire)
Re:
« Reply #2 on: August 27, 2013, 10:23:00 pm »
Jas
Everything else works fine.  :happy2:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #3 on: August 27, 2013, 10:25:37 pm »
Other doors unlock from the remote locking OK?
Re:
« Reply #4 on: August 27, 2013, 10:27:22 pm »
yes... only drivers door effected
Also when i unlock it with the fob, if i open the px door and try and open the driver door, i cant. Its like its not lifting the dead lock or something!
Offline doylebros
  • -Receive: 310
Re: Random drive door lock issue
« Reply #5 on: August 27, 2013, 10:33:14 pm »
Should show in a scan  -  have you noticed if the door LED flashing rate has changed?
« Reply #6 on: August 27, 2013, 10:34:19 pm »
Will scan it tomorrow... not notice anything with the LED other then when i got the door open it flashed a lot. ( i think)
Offline doylebros
  • -Receive: 310
« Reply #7 on: August 27, 2013, 10:35:58 pm »
If when locking it flashes fast - typically new module required!
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #8 on: August 27, 2013, 10:45:40 pm »
Almost certainly a new door lock control module. It might go away for a while-mine does it in hot weather so it doesn't happen often. It shows up as an intermittent failure on vcds.
'07 Red manual
« Reply #9 on: August 27, 2013, 10:47:07 pm »
Ill check some old scans to see if anything is mentioned.
« Reply #10 on: August 27, 2013, 10:48:54 pm »
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
            012 - Electrical Fault in Circuit - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
Thats from an old log... funny how its not caused any problems until recently
How much is a new module... and is it easy to fit?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #11 on: August 27, 2013, 11:15:02 pm »
They're about £150.
There is a guide in the troubleshooting section which you are supposedly moderating :wink:.
'07 Red manual
« Reply #12 on: August 27, 2013, 11:16:07 pm »
They're about £150.
Got a link to it....  :wink:
 :signLOL:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #13 on: August 27, 2013, 11:20:13 pm »
Have you had any other electrical problems?  I think I remember reading you had a new TB fitted (my current problem) only say this because I've had the drivers switches and motor problems, had to swap them out... Does your alarm work? Had to swap that out too and the wiper motor, and the cruise control... Hmm.
There a big thread on Audizine that seems to suggest a lot of issues are caused by bad wiring/earthing or ECU.
« Reply #14 on: August 27, 2013, 11:21:57 pm »
I had the TB issue.. but apart from that no other issues. (apart from an annoyingly crackly radio reception)
