Author Topic: Just fitted CC stalk and MFSW...steering angle sensor error  (Read 1911 times)
Offline Rob.
« on: September 03, 2013, 09:13:30 pm »
As far as I can tell, I just managed to fit an R32 MFSW (thanks Steviedubs) and a cruise stalk (thanks Eddie-NL) without any major issues.
I've been left with the steering angle sensor error on the dash, as well as an ESP one. As far as I can tell, the first one is pretty common; is the ESP one too?
My questions is...am I OK to drive the car? I took it for a test and the steering is fairly heavy...but I'm not able to see my man Scaff with his VCDS until Friday night.
Thanks.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Just fitted CC stalk and MFSW...steering angle sensor error
« Reply #1 on: September 03, 2013, 09:22:09 pm »
Have you tried turning the wheel to the left then to the right and driving a short distance
Sounds like you might need to perform basic settings with VCDS
Cluster and Key coding
Location Great Yarmouth
Offline Rob.
« Reply #2 on: September 04, 2013, 10:01:29 pm »
Drove it to work today and noticed the wheel is slightly off centre  :ashamed: And I thought I'd be careful in re-fitting it to the notch on the bolt!
Do I need to re-centre before getting it on VCDS?
Offline doylebros
  • -Receive: 310
« Reply #3 on: September 04, 2013, 10:25:20 pm »
The wheel can be realigned any time but the nut only has so many operations before replacement!
The VCDS is need to allow the following since the CC install
http://uk-mkivs.net/forums/p/326876/2201804.aspx
Other than that the steering angle sensor reset is none VCDS operation.
« Last Edit: September 04, 2013, 10:28:20 pm by doylebros »
