September 03, 2026, 05:08:11 am
All Things Mk5
Sat Nav and Car Audio
RNS510 and MK6 steering wheel buttons.
Topic: RNS510 and MK6 steering wheel buttons. (Read 1584 times)
sanj
Won't Shut up.
-Given: 17
-Receive: 26
September 07, 2013, 06:02:54 pm »
I've just installed this on my Edition30 which has a MK6 MFSW fitted and was wanting to know how to get the left/right button's when scanning radio station's to work,I have a VCDS cable,all other button's work as they should do.
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: RNS510 and MK6 steering wheel buttons.
Reply #1 on:
September 08, 2013, 04:14:10 pm »
the left and right buttons will only work if BAP is ticked in the RNS
If you have a Highline don't do it as you won't have NAV and AUDIO menus any more
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
sanj
Won't Shut up.
-Given: 17
-Receive: 26
Reply #2 on:
September 08, 2013, 05:16:30 pm »
Thank's for the reply Eddie,i've since found out that it's the right side up/down button's on the steering wheel that control the radio station's so it doe's work after all!
kalu
Always Involved
-Given: 4
-Receive: 9
Reply #3 on:
September 09, 2013, 01:54:42 am »
You can get all the buttons to work, but you must fit BAP clocks (from late Scirocco or similar)
All Things Mk5
