Author Topic: Canbus gateway help  (Read 2904 times)
Offline al200
Canbus gateway help
« on: September 29, 2013, 09:06:49 pm »
Hi, I need some advice please. May seem like a stupid question but I need to ask.  I'm upgrading my radio to an rcd510 and need to check what canbus model I have as I have a 56 plate gti. Can I simply unplug the canbus gateway to check the part number on it and plug it back in again with no issues? Or do I need vagcom to plug it back in again?
Any advice would be much appreciated.
Re: Canbus gateway help
« Reply #1 on: September 29, 2013, 09:10:29 pm »
You should be able to remove it from its holder and be able to look at the P/N without actually disconnecting it.
Offline bacillus
  • -Receive: 453
« Reply #2 on: September 29, 2013, 09:23:54 pm »
The easiest way to check is to do a vcds scan.
I suspect with a 56 reg car you will need an updated gateway.
Offline skard
  • -Receive: 245
« Reply #3 on: September 29, 2013, 09:28:38 pm »
Mine is a 56 and has a K gateway, and the one with the software revision that drains. Same with our 07 Altea, you might be lucky but don't bet on it.
Offline woahnowboys
« Reply #4 on: September 29, 2013, 10:07:20 pm »
Fitted an RCD510 in my 56 plate recently.. I needed a new canbus, like others have said, probably will need a new one, but you may be lucky :smiley:
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
Offline al200
« Reply #5 on: September 30, 2013, 05:38:46 am »
Thank you for the replies. I will look into this week but from the sounds of other people's experience I will need to get a newer version.
I've heard some people claim that you can just re-programme the existing one. Anyone know if this is true?
If not, there is someone on ebay selling pre-coded ones for £85. Looks like the way to go. Anyone had experience of these?
Offline skard
  • -Receive: 245
« Reply #6 on: September 30, 2013, 07:50:31 am »
That person on ebay will be Eddie-NL here, pretty sure it is cheaper if you contact him directly.
If you have a K revision I think it can be reprogrammed, however for the costs involved you are best off just putting a newer part in and removing the doubt.
Offline woahnowboys
« Reply #7 on: September 30, 2013, 03:02:28 pm »
Aye, I got mine from Eddie_NL, just give him a PM :happy2:
Came the next day too :)
MK5 Daily.
Offline Horatio
  • -Receive: 39
« Reply #8 on: September 30, 2013, 03:26:47 pm »
If you dont have access to VCDS just call any VW dealer, give them your reg number and they will give you the part number over the phone.
Offline al200
« Reply #9 on: September 30, 2013, 09:20:10 pm »
Didn't realise vw would have that information. I'll give them a call tomorrow.
Just checked and it does seem to be eddie_NL. Good to know that he's a member. Sounds like he knows his stuff. If  VW tell me its an older model I'll have to order one from him.
Thanks for the replies.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: September 30, 2013, 10:35:04 pm »
The only problem you might have is that they will give you the current part number that you can order
Cluster and Key coding
Location Great Yarmouth
