Author Topic: WTF - Tech Note on service - Lower Turbo Pipe Leaking  (Read 15078 times)
Offline nc35
  • -Given: 40
« on: September 03, 2009, 10:41:20 pm »
Hi All
Just spending a little time looking through the paperwork that cam with my car.
Just over a month ago the car was serviced at Smith Knight Faye, Bury.  There is a Technicians note that " OSF Lower Turbo Pipe Leaking"
Can anyone tell me what this means, is it an easy fix and why on earth wasn't it fixed.
Dealers for you I suppose
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: WTF - Tech Note on service - Lower Turbo Pipe Leaking
« Reply #1 on: September 03, 2009, 10:55:54 pm »
Probably oil leaking from one of the pi$$ poor joints in the pressure pipework.  Quite common.
If you are under wty ask them to sort it.
Stu...
Offline nc35
  • -Given: 40
« Reply #2 on: September 03, 2009, 11:03:39 pm »
Nope - 4yrs old with aftermarket warranty...
Is it a DIY fix?
No Golf anymore.
Thank You Everyone.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: September 03, 2009, 11:09:58 pm »
I think they normally replace the pipe, IIRC the seals aren't a seperate pipe.
There is a pipe that runs from the turbo out, round  towards the front, past the bottom pulley and on to the intercooler.  I suspect it's this one they mean.
Stu...
« Reply #4 on: September 04, 2009, 12:04:31 am »
The turbo impeller shaft bearing floats on oil, which is supplied by pipework. This is the only pipe I know that could leak and it is not good :scared:
Offline nc35
  • -Given: 40
« Reply #5 on: September 04, 2009, 12:24:19 am »
Think I am going to invest in a Haynes manual.
Try and sort this myself, you obviously can't trust anyone any more  :confused:
No Golf anymore.
Thank You Everyone.
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #6 on: September 04, 2009, 01:00:36 am »
i thought i had a small oil leak around the turbo area, but having just driven 1800 miles and not loosing any oil, i cant have,
my DV area had traces of oil around it. il keep an eye on this thred so please report your findings,  :smiley:
Offline BeezerDiesel
  • -Given: 33
« Reply #7 on: September 04, 2009, 05:30:28 am »
I'd go with Stu's theory too. Turbo to intercooler pipes can often slightly leak under boost. It would be worth phoning the dealer and asking to speak to the techie who did the service whilst it's still fairly fresh in his memory. He'd also be able to give you his opinion on whether he'd recommend you did something about it now or wait until the next service to see if it had deteriorated any further. An intercooler pipe will be under more pressure if the car is re-mapped and running higher boost so that can exacerbate a problem.
On my last service I was told an intercooler connection had a slight leak but not to be overly bothered about it as it was very minor. The connector can't be bought seperately (as above) so a new pipe would be required, likely cost of around £50.
Andy
7R
« Reply #8 on: September 04, 2009, 07:57:20 am »
....Which is why I upgraded all my turbo piping as a precautionary measure. VW, and others, don't manufacture their cars to accommodate aftermarket tuning.
The dealer isn't doing anything wrong by informing you of the leak - In fact quite the contrary - It's up to you to read the paperwork and to remedy, or instruct them to remedy, potential problems accordingly. However, a more helpful dealer would go through the paperwork details with you at the time of payment.
Offline nc35
  • -Given: 40
« Reply #9 on: September 04, 2009, 10:27:34 am »
Got to ask....
What are all those pipes??
Cheers RRR
No Golf anymore.
Thank You Everyone.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: September 04, 2009, 10:30:54 am »
It's a Forge (or similar) Silicone Intercooler hose kit, a Forge (or similar) Throttle Body hose, a Neuspeed Turbo Out pipe and a Neuspeed Inlet pipe.
« Last Edit: September 04, 2009, 10:36:40 am by vRStu »
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
« Reply #12 on: September 04, 2009, 11:28:43 am »
....Substitute SAMCO for Forge and it's called "Turbo Hose Kit" by SAMCO.
Spot on, Stu. But no prizes! :drinking:
Offline nc35
  • -Given: 40
« Reply #13 on: September 04, 2009, 12:24:03 pm »
Don't suppose any of that kit is what I need?
Bit cheeky but is any of it for sale?
Sorry to ask
Lee
No Golf anymore.
Thank You Everyone.
« Reply #14 on: September 04, 2009, 01:57:35 pm »
Sorry to ask
Lee
....Do you mean the oem pipes in my pic, Lee?
