Author Topic: Slack gear lever whilst in gear  (Read 1195 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« on: October 16, 2013, 04:51:19 pm »
Been a problem for a while this one, used to be fine.
Whilst in gear, any gear, there's about 2-3cm of sideways movement, engaging gears is fine.
I've tried resetting the gearlinkages, even replaced a worn bush, but it didn't make any difference.  Is there anything else I could try... is it perhaps a localized gear stick problem?
Anyone else got this?
Offline doylebros
  • -Receive: 310
Re: Slack gear lever whilst in gear
« Reply #1 on: October 16, 2013, 05:12:34 pm »
This may help
By the way the cable has those bushes on both ends of the cable not just the gear box end!
« Last Edit: October 16, 2013, 05:28:06 pm by doylebros »
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #2 on: October 16, 2013, 05:53:02 pm »
Thanks mate, yeah, not sure the DD's will make any difference, but thanks for the link. :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #3 on: October 17, 2013, 10:44:46 am »
Any further recommendations?
Offline Trekmeister
  • Golf GT 140
Re:
« Reply #4 on: October 17, 2013, 03:48:54 pm »
Im in the same boat
Offline doylebros
  • -Receive: 310
« Reply #5 on: October 17, 2013, 09:35:14 pm »
If the rear bushes (cables to lever)don't fix it then it could be the gear knob fixing as shown in here or the gear lever bottom bush which is cheap and easy replacement.
http://www.myturbodiesel.com/1000q/a4/shifter-boot-replacement-leather.htm
« Last Edit: October 17, 2013, 09:41:13 pm by doylebros »
