Author Topic: Crunching gears  (Read 1979 times)
Offline youngy1989
Crunching gears
« on: October 25, 2013, 07:13:26 pm »
Hi all
Most times when i put my tdi in to reverse its crunches, and its tough to put it into 1st.
Also i pulled at home tonight on a bit of a slope and i couldn't get the car into gear 1 3 or 5 i only just managed to get it into reverse. So i reversed off the drive and then the car could go into gear.  :confused:
Could it be the gearbox or clutch on its way out?????.
The car has 112 on the clock
All comments appreciated
Offline doylebros
  • -Receive: 310
Re: Crunching gears
« Reply #1 on: October 25, 2013, 09:34:18 pm »
Start with the cheapest first:-
Is it cold weather dependant?
Look at the clutch pedal for failure
Adjustment of the gear linkage or bush replacement
Check brake fluid level - Bleeding of the slave cylinder
Check gear box oil level
Looking at testing the clutch for operation soundness!
If none of the above your looking at clutch or box  - both expensive!
Offline youngy1989
Re: Crunching gears
« Reply #2 on: October 26, 2013, 08:33:59 am »
Ive had the gearbox oil changed yesterday morning. And no change.
The clutch pedel sometimes sticks at bottom. And the bite is right at the bottom
Been looking on other sites ppl say it could be the slave cylinder or/and master cylinder
